Question about Panasonic SC-AK71 Shelf System
SA-AK91 Doesn't detect CD Door closed - not a switch problem
I took this stereo apart to fixed a band slippage issue on the cassette deck right after buying it. When I put it together it kept saying the cd door was open. It wasn't a switch problem. Switch works normally. All wires are good. No breaks or damage to anything. I've taken it apart several times since this problem and each time I did thorough testing of every wire in every cable. No use. I never got a chance to use or enjoy the CD player in it. Any help would be greatly appreciated. Note that when I had it apart the first time before it broke I didn't short anything and the power was disconnected.
    Top Expert:
  • Panasonic Master
  • 26,177 Answers
Check the door switch is in the correct position.
Posted on Apr 15, 2017
zair
  • 82 Answers
SOURCE: SA-AK91-TECHMAN
Recheck the joints of the terminals that join the boards together. Resolder the power supply.
Posted on Mar 29, 2008
  • 4 Answers
SOURCE: Nide code fore a panasonic cd stereo sistem
if you get a tv repair man he can fix and order the part that is the problem it is a twelve pin plug that needs specilist tools to remove. The part is an amplifier chip, common problem with the sa-ak600.
Posted on Mar 20, 2009
SOURCE: my cd stereo system sa-ak630 wont come of demo mode what do i do
there is a button on the left side that says "-demo" on it. hold that button until it stops...
Posted on Jun 14, 2009
SOURCE: my CD Stereo System SA-AK18 turns off itself
My stereo turns off and displays F61. How do i fix it.
Posted on Nov 11, 2010
SOURCE: cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
Posted on Apr 09, 2011
My sony mhc-bx7 makes a strange clicking noise 3 times when you turn it on and it then says tape b on screen then says eject and powers down. what is the fault and can i fix it?
Dual cassette deck are nothing but trouble, but on occasion they can be made to work a little longer. Maybe lose belts or the most common thing is the grease is all dried up. It requires the cleaning off and application of new better grade grease. The problem is the mechanism has to come apart and make sure it is aligned when put together- this can take 3 hours.
Aug 27, 2016 | Sony Audio Players & Recorders
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
Tape deck on Panasonic RX-DT680 boombox issue
I think this should be a simple fix! The deck will have switches at the top of the cassette compartment. These detect the tape and also select it for type - metal or chrome etc. These switches have become bent or damaged or have dirt on them.
May 18, 2013 | Audio Players & Recorders
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
Malfunctioning CD, Cassette, Radio stereo
With all due respect, it is not the sort of fault a novice can fix with any competence. It has power supply and system issues.
Jul 12, 2017 | Panasonic Sa-pm27 Shelf System 5 Cd...
Defective cassette adapter for iphone 4s. stuck in side of the cassette deck
take the deck apart, get the tape and put it back together or see if you can find someone who fixes decks and ask them to take the tape out
Jun 16, 2012 | Dynex Mp3 Stereo Cassette Adapter Dx-ca103
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
82 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
