Question about Konica Minolta Office Equipment & Supplies
Bypass tray slot location - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,674 Answers
What model????????
Posted on Dec 29, 2015
Co960 2510
Sir/Mam
You mite want to check the manual bypass tray located on the rightside of the copier below the side door, looks like a step!!!! The rollers maybe dirty or the something stuck in it. if printing to the copier and asking for the bypass tray recommended that you send the print job over to the machine first then place the paper in the tray when the machine indicate to replenish paper in the bypass tray. It is important that when using 81/2 x 11 papaer that you look at the little icon on the operator screen to see weather to place the paper on the bypass tray in potrait or landscape paper will jam if not seated properly.
Aug 06, 2014 | Minolta DiALTA DI2510F All-In-One Laser...
Paper jam when print from tray 2
There is Registration Sensor located near the bypass tray.Please clean the sensor or else replace the sensor or DC board.Orelse please check the pick up roller solenied switch( spounge in solenied may be torn out replace with another spounge)
Apr 05, 2014 | Genuine Konica Minolta Konica Minolta...
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
How do I get the printer to print automatically using the bypass tray
you can set the bypass tray the size you want then set paper size setting in the printer driver at your PC.
Hold down the [PAPER SIZE ENTER] key more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
Use the [ORIGINAL SIZE ENTER] key to select the paper size you want to set.
The indicator of the selected paper size lights up.
Press the [START] key and then the [PAPER SIZE ENTER] key.
To change the paper size setting of another tray, repeat steps
after pressing the [START] key
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jul 01, 2011 | Toshiba E-Studio 161 Copier
My Di 2510 konica minolta problem is cod co 960 cane u solve the problem.
Sir/Mam you mite want to check your bypass tray located on the right side of the machine. If printing to the machine recommended that you send the print job over to the machine before placing paper in the bypass tray and wait for the machine to indicate to replenish paper in the bypass tray. When that occurs look at the icon on the operators panel and notice the icon after the 81/2x11 paper and make sure you place the paper properly in the tray landscape or portrait the copier knows how long the paper should be if in landscape the copier is asking for portrait. and vise a versa.
Oct 30, 2010 | Minolta DiALTA DI2510F All-In-One Laser...
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
How do i put paper in the bypass feed of the OKI printer? I can't find the bypass tray or how it put in a thicker paper.
The by pass tray is located in the right side on copier machine.Insert the paper select the tray and made a copy.
Aug 19, 2009 | Ricoh Aficio 250 Copier
Brother printer mfc-7420 will not print
Manual feed is a by-pass tray (not the paper tray,)
in this particular model it looks like one of hte slots in the front. put a paper in and see if it grabs it.
you should be able to cancel out the job by pushing stop/cancel?
1-check the tray to make sure the paper size is correct
2-make sure it is set for tray not bypass
Jul 30, 2008 | Office Equipment & Supplies
Message: add paper to paper tray
Clean photosensor or replace actuator on feed roller assy , try to use caned air to blow off sensor located above tray , if you reach in tray slot after removing tray you can feel a black actuator that swings. look there !
Apr 25, 2008 | Sharp AR-168D Copier
Printing
There are 3 different locations where paper trays are selected.
1 is on the machine.
2 is in the print properties on the driver
3 is in Word itself, in differeing locations on the top tool bar depending on the version you are running.
I doubt you have to install anything, just one of those locations has your bypass selected. Maybe someone was running envelopes or labels and wound up selecting the bypass as the default tray in word, or again the driver properities.
This one is just searching through the driver and programs until you find the location that the bypass is selected as the default tray.
Just persistance, and yeah can be frustrating finding the exact location of the change.
Feb 22, 2008 | Canon imageRUNNER C3200 Color Printer
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
