Question about Measuring Tools & Sensors
How long to fully charge a SoundLogic xt power cell?
How long does it take to charge the power cell?
4 Suggested Answers
  • 11967 Answers
SOURCE: no power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Posted on Aug 02, 2010
  • 530 Answers
SOURCE: How do I set the time on the Soundlogic XT Bluetooth Digital Entertainment System?
Go to menu.
Posted on Feb 02, 2015
AndrexT
  • 16685 Answers
SOURCE: My charging port is broken what sould I do on my soundlogic xt indoor outdoor speaker
Buy a new one for $24 and be more careful I am afraid.
Amazon com Portable Rechargeable Wireless Bluetooth Indoor Outdoor Party...
The only other option would be to take it apart and see if you can find a good electronics parts store.
http://www.rs-components.com/index.html
Posted on Dec 10, 2016
What is the function of the on/off switch. to save battery or to have on when charging and off when charging at the wall oulet?
On a cell phone it is to extend battery life when the phone is not required. Some phones will still retain some functions eg alarm clock, even when off. You don't need to turn the phone off when charging, but it will charge up faster if you do.
Mar 13, 2015 | Cell Phones
I charged phone it won't turn back on now
Remove the battery.
Remove sim and replace.
Replace battery.
Turn on the power and hold the power button!!!
If this doesn't work, could be charger is faulty, or battery was knocked during charge and didn't charge (I have had this one in the past).
Do you charge with charger or USB?
Feb 24, 2015 | Samsung Galaxy S 4G Cell Phone
MY PHONE WONT CHARGE
The power cells lost the ability to accept a charge. Noting you can do will revive the energy absorption. Replace the power cells and charge for 24 hours. Use the phone until the charge has completely drawn down and the phone shuts off. Re-charge over night to set the battery memory for a full charge. Your done!
Feb 26, 2014 | ZTE Warp
My iphone 4 8GB only charges when powered off. It doesnt show charging symbol and wont charge while powered on. Not jailbroken. Itunes doesn't recongnize it while plugged in to laptop I tried 4 di
First, make sure that if your iTunes version is high enough to fit the version of your iPhone.
About charging, I think it means the output current of your charger is to low to charge and run your iPhone at the same time. This case is most like that, when a iPad 2 link to PC it won't charge when the scree is on.
If you are using digital products frequently, you can try to get a dual USB output external power supple, which hold on 2 type of output current 1A for common cell phone, 2.1 A for iPad, Pad PC and some device which need high charge current
Apr 03, 2013 | Apple iPhone Smartphone
My x8 not turn on and not charging !!!
Good morning:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 04, 2013 | Sony Ericsson XPERIA X8 Cell Phone
Bought new battery for cell phone, wont charge or turn on
did you try a new charger not the best solutinon
Jun 11, 2012 | LG Rumor 2 Cell Phone
My cell phone will not charge,,What can I do?
Ifthe phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.Check power adapter's DCplug that connects into the cell phone power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.
Apr 14, 2011 | AT&T Cell Phones
Battery power is very weak
    1. Try this first  power off your cell phone and charge it for 6 hours
    2. remove the charger and power on your cell phone start using it
    3. please note that don't use your phone while charging unplug it if you need to use
    4. only recharge it when it shows battery is low
    5.  please buy and use original battery and  charge
    6. I am sure that you can see the difference
    Jun 20, 2010 | Nokia 6500 Slide Cellular Phone
    E010 S95986 HSB power cell does not hold charge
    Change the capacitor. This is the thing accumulating the energy. As the ordinary batteries, it may go bust, so, all you have to do is to replace it. There is no such a name as power cell in Citizen EcoDrive watches - there are CAPACITOR. Capacitor absorbs the energy from the light sensitive panel(s) and dispenses it in the ordinary battery manner. Advertisements are saying that you will never have to change the battery - that's right, because there are no batteries at all. Instead of battery there are CAPACITOR, but nobody says it will last forever. Rate me, plz.
    Mar 05, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
    SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
    battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
    Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
    Measuring Tools & Sensors Logo
    199 people viewed this question
    Top Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
