Question about Panasonic KXT 61610 R3 Key Service Unit Phone
2 lines comming in, Busy signal on main line when used
Does the main line get forwarded to 2nd line when in use? Then to 3rd and so on? Is this internal? or do I have to call my phone provider to set this up.? Thanks for your time!!! I am also looking for a complete manual on this system. Thanks again
You need to call your provider to make the lines hunt. For a manual, you can try www.telemanuals.com
Posted on Jun 23, 2009
Where is the kata repair center can you sms me or call me at 88582030
Store Location ' Kata
www.katadigital.com.ph/store-location/
2nd Level Cyberzone, Lucky Chinatown Mall 3rd Level, SM City Clark 2nd Level Cyberzone. Robinsons Place Metro East 3rd Level, SM City Baliwag 2nd Level
Kata ' Making Life Easy
Home · Mobile Phones · Tablet PC · Accessories · KataCloud · Store Location · About Us. 3. Kata T4. T4-main-banner. Kata Box. kata-box-main-banner. F2.
Jan 19, 2016 | Cell Phones
How to divert an incoming call?
There are several methods. Phone company provided call forwarding instantly sends calls to a phone number you set on your main phone line, that you turn on with *72 + the destination # and turn off with *73. Or "Call Forwarding No Answer" that transfers the call after several rings to a pre-determined number, all setup by the phone company on your main line. Or, on the Panasonic systems (there are many), you do the same using several code choices, a bit more complicated. Your installer must set the system to allow the system to send calls to an outside line, and you must have more than one line because the destination number is dialed on a different line than the line that's receiving the call. Your Panasonic "Operating Manual" lists these codes and methods with instructions, you'll find them listed in the table of contents under "Call Forwarding" with step by step pictured instructions.
Apr 09, 2014 | Panasonic KX-T7730 Corded Phone
I have a 1998 dodge Grand Caravan with codes P0700,P0734 & P0733. What does this mean?
P0700 is a informative transmission code, about some problem there; the P0733 and P0734 is the specific problem there.
I would first try changing the fluid and filter. Although the fluid may look like it is brand new, with 100K on the fluid, I can assure you that even if those miles were all highway at steady speed and no load that the fluid has deteriorated and no longer lubricating the internal parts properly and that there is some debris in the ******.If codes return and shifting problems are still present, there is definite internal failure, possibly the pump or in the clutches.
DTC P0733The powertrain control module (PCM) uses the crankshaft position (CKP) sensor, input speed sensor (ISS) and output speed sensor (OSS) to determine engine speed, input shaft speed and output shaft speed. These sensor readings are used to determine the current gear ratio and RPM slip across the torque converter. The PCM uses this information from the sensors to determine if the commanded gear matches the actual gear. During normal driving conditions, the PCM will adapt main line pressure via the pressure control (PC) solenoid to prevent slipping and harsh shifts. Shift solenoid 3 is used to apply or release third gear clutch. The PCM controls 3rd gear by controlling the ground for shift solenoid 3. The PCM will turn the solenoid OFF, open the driver circuit, when 3rd gear is commanded On to apply 3rd clutch. Shift solenoid 3 is supplied ignition voltage from the fuel pump relay whenever the PCM commands the fuel pump relay ON. DTC P0733 sets when 3rd clutch still slips after the PCM has commanded high main line pressure.DTC Parameters
DTC P0733 will set if the PCM detects an incorrect actual 3rd gear ratio when 3rd gear is commanded On when:- The condition exists for longer than 3 seconds (2001)*- The condition exists for longer than 3 seconds, 1 minute is allowed to elapse, then condition exists again for longer than 3 seconds (2000)- The high main line pressure has been commanded- The transaxle is in a forward gear- The input speed is greater than 224 RPM- The vehicle speed is greater than 5 km/h (3 mph)- The speed noise parameter = NO- The steady state ratio fail counter equals 255 for an in-gear failure, or the shift fail counter is greater than 100 on a downshift or upshift to 3rd gear (128=0 or normal operation)DTC P0733 diagnostic runs continuously once the above conditions have been met.
DTC P0733 is a type A DTC for 2000, type B for 2001.**Applicable to vehicles built after June 2000.
Diagnostic AidsImportant: If DTCs P0745, P0746, P0756, P0758, P0761, P0763, P0766, P0768 or P0789 is set, diagnose that DTC first. A diagnosed PC solenoid, shift solenoid 2, 3 or 4 low/high circuit fault DTC may have caused DTC P0733 to set.Important: If a shift solenoid performance DTC P0783, 4th gear stuck ON, is set, diagnose that DTC first. A 4th gear stuck ON may cause no 3rd gear, no 2nd gear, or TCC stuck Off.
Refer to Pressure Ports - Air Check and Parts Description for pressure apply points and for component/location description.
Possible causes of no 3rd gear are listed in the flowchart on the succeeding page.
Verify TRANSMISSION ISS and TRANSMISSION OSS read correctly on Scan tool.
Make sure the pressure control, shift 2, shift 3 and shift 4 solenoids are not intermittently sticking. A sticking shift solenoid 4 may cause 4th gear to be applied from an initial start resulting in no 3rd gear. Audible sound should be similar for all solenoids. A muffled tone indicates the need for replacement.
Check this pinout HERE
P0734 refer at ratio 4 gear, and the rocedure is the same.
Hope helps.
Jan 22, 2013 | 2003 Dodge Caravan
Codes p0700,p0733,p0734 dodge caravan 1997
Hope helps.
Apr 03, 2012 | 2003 Ford Focus
How to unforward a phone from the main line
press the call forward key on the set that is forwarded. if no forward key press feature # 4.
Feb 15, 2012 | NorStar M7310 Corded Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Dec 07, 2009 | Nortel Norstar 16-Line PBX Speakerphone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
Norstar 7310 forwards to Voicemail
Sounds like the phone is set for Call Forward Busy/ No Answer instead of Call Forward No Answer. If you cahnge it call forwarding it should work correctly. ....Mike
Aug 08, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
63 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
