Question about Raymarine E32042 Raystar 125 Gps Sensor
Raystar 125 GPS Sensor problems - Raymarine E32042 Raystar 125 Gps Sensor
There are 5 wires . What color wire go to sea talk and where do the others go?
From page 4 of the owners manual (link below), there are a couple of ways the cables could be connected depending on which setup you have.
Hope this helps.
-Steve
https://www.sv-zanshin.com/manuals/raymarineraystar125gpsownershandbook.pdf
Mar 11, 2015 | Raymarine Raystar 125 Gps Sensor
My GPS Raymarine (installed in 2001) with Raytheon Raystar 120 antenna indicate offen a NO FIX. A technician tells me that there must be a problem with the antenna and that the best solution is to...
Before you buy a new one if that is a raytheon raystar unit there is a lithium battery inside the unit check that first thats all you may have to replace.
Sep 04, 2010 | Raymarine Raystar 120 GPS Receiver
We lose fix info. on the c120and the Auto pilot has no display. The problem is intermittent
This sounds like a problem with the receiver. If you can not get GPS fix (sometimes) you will have to start looking at the GPS antenna and cable. If the unit is new check out the location of the antenna. As with anything that works with satellites it need a clear view of the sky to fix onto the "birds". A GPS connects to numerous "birds" at a time, so ensure that the antenna has a wide angle view of the sky. If it is old you will have to start looking for connection problems. This is usually the case when the fault is intermittent. Check for possible water damage and loose or less than adequate connections. Also ensure the cable is in a good condition.
Apr 03, 2010 | Raymarine C120 System Pack C120 Raystar...
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
My Raystar 120 GPS keeps losing its fix.... the fix comes b ack a few minutes later, but then i lose it again. I have tried a cold restart, but the problem persists. Ideas?
Guys, most likely the litium battery is eol. Buy a new litium 3 volts battery for 3-4 euro's with soldering points . Use a pair of scissors, note the plus and minus side of the poles and carefully cut out the battery leaving enough metal to solder a replacement battery. Solder the replacement battery, and the problem is fixed. You're ready for another 6 years of fun saving 300 USD for a new GPS!
Oct 10, 2009 | Raymarine Raystar 120 GPS Receiver
Raymarine looses GPS fix
A software upgrade will do a world of good for the unit, however it may not take care of your GPS fix issue. Usually when you have satellites showing and no fix, that indicates a bad antenna. Check the LED indicator on the antenna, it should be green. The RS125 has a connector plug on the antenna end so it is nice and easy to buy a new one and give it a try. The software is free and a good start.....and yes you need to do a reset after the upgrade by holding the first soft key as you power on the unit. It will give you a factory reset countdown. Simply hold that soft key until it is done and begins the reboot.
Jul 10, 2009 | Raymarine C120 System Pack C120 Raystar...
Ear Sirs, I have problem to get a GPS fix on my Raymarine C70, I have a Raystar 125 which is connected through E85001 interface, The first time I connected the deviced together it works, and I got...
Hi Arne,
What I understand is you might not have gone through the user manual for C70 as its clearly mentioned about the settings. Once when you have it set up correct then we can come to troubleshooting mode whether something is wron or not.
I would therefore request you to take out some time and go through the manual first and then try connecting or setting it up.
http://www.raymarine.com/SubmittedFiles/Handbooks/c_series/81221_4.pdf
Thanks for contacting Fixya.
Jun 24, 2009 | Raymarine C70 GPS Receiver
Problem getting a proper fix
The antenna should be replace by raystar 125.
Regards
Michel
May 31, 2009 | Raymarine RL70CRC GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
Raymarine E32042 Raystar 125 Gps Sensor Logo
29 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
