Question about Kenmore 62602 Electric Dryer
How to remove control panel on kenmore dryer model 110.64942300?
  • 161 Answers
SOURCE: Directions to replace gas valve - Kenmore dryer model 41790042990
If you have a 2 piece front panel just pry the bottom part open from the top, right under the door. It will swing down and lay flat. You can remove the gas valve assembly now. It is on the left. If you have a one piece front. remove the lint filter and then the two screws there. Be VERY careful not to drop anything down the hole. (It will ruin the fan.) Pry the top off by using a butter knife or thin screw driver to push in the clips in the front corners. It will swing open from the front. remove the wires from the door switch. Use a 5/16 socket to remove the screws holding the front panel in place. Pull out and up the bottom is held by clips. Be careful not to let the drum fall all the way out. When you reassemble the dryer before you put the top down , turn the drum a full turn to make sure that the felt seal at the back is seated properly.
Posted on Jun 29, 2008
SOURCE: Dryer not heating
what is the model #the heater is not in the back of the he4.
Posted on Nov 05, 2008
Maytag317
  • 1136 Answers
SOURCE: Remove front panel - no heat and buzzing sound
Hi, If the lint screen is at the top of the dryer, remove the screws located at the lint screen. Then pry the top by inserting something flat into the gap between the top and the front panel. Now locate the screw inthe upper inside corners and remove them. Now the front will lift up and release from the cabinet.
If the lint screen is inside the door, the lower half front panel will release and let you see under the drum.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on May 22, 2009
rogrrabbit
  • 986 Answers
SOURCE: how to remove back panel from kenmore electric dryer 110.68972892
Find your manual and follow the instructions
http://sites.google.com/site/sublimeappliancerepair/manuals
Posted on Sep 12, 2009
  • 127 Answers
SOURCE: dryer won't heat
The back panel doesn't come off for service!!! Most heating and control components are available behind the kick panel below the main dryer door..
With electric dryers my normal train of thought in diagnostics is to start with source of power. Do I have 220 volts available at the terminal board where the electric cord is connected??? Quite often I find a blown fuse, etc to cause it to stop heating as the motor will run fine on 120 volts as thats all it requires, but the unit will not heat with out 220 volts to the element..
best of luck, and have fun,
ttfn
Posted on Feb 02, 2010
How do you open up the kenmore dryer model 80311900 with the front control panel for cleaning out lint
To disassemble the machine, disconnect the power!
I believe that model has two screws in the rear edge of the top panel. Remove the screws and slide the top panel to the rear and remove it. Then remove two screws, from inside the machine, that hold the front panel in place from the back. Label the wires, then disconnect them. Tilt the front panel forward, then lift the bottom of the front panel up.
Mar 05, 2017 | Kenmore Dryers
I have an 2008 HE2 kenmore dryer that won't run. Model # 110.8756 2602 when you turn it on it clicks then reads 01 then F- Is it a fuse or entire control panel?
unplug the cord from main power then remove main control board there should be a jumper in the upper left corner see if its connected to the plug beside it if not connect could have came off during shipment or the unit was dropped
Dec 27, 2014 | Kenmore Dryers
Belt replacement on Kenmore Dryer.
The first thing I do is remove the top. Then I drop the splashplate and remove the controls. If this is the first time you have messed with it their are some zipties that need to be removed. then the controls unplug and the control panel is set aside. The drum is real heavy. If you are 10 feet tall Tarzan you might can get it out by using the belt to assist you after you have removed the idler. A trick is just remove the 3 screws to the rear drum bearing and get the drum out. Then re-attach it to the drum before you install the drum back in the dryer.
Assorted dryer service manuals and more
Aug 30, 2012 | Kenmore Dryers
How do I get the control panel face off on a Kenmore model 110.72942100 gas dryer? The start switch has failed, but I can't figure out how to get at the switch without breaking something. There are...
Take the knob off of the switch. Then lift the locking tab on the backside of the switch, twist it a hair and it will drop right out the back side of the control.
Sep 03, 2011 | Kenmore Dryers
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Need kenmore electric dryer model 110.66662500 wiring diagram. will not heat
Should find the wiring diagram under or in behind the control panel accessed by removing the 2 screws holding the panel down either in the front lower or rear lower end caps . If you can't see any screw heads there may be removable covers on the end caps from top to bottom . On some newer models you can insert a putty knife under the end caps on the front and depress a clip on either side and the whole control panel lifts and lays back. Before any of that check your fuses at the panel 2-- 30 amp
Nov 04, 2010 | Kenmore Dryers
Kenmore model 417-how to get to fuses in control panel. 03 model
unplug remove the back and you will see one fuse on the left side of heater box,and the other on the blower box(white)
May 06, 2010 | Kenmore 73952 Gas Dryer
Where is the heating element in the kenmore dryer
It depends upon the model number.
Most Kenmore dryer elements are accessible after you remove the rear panel of the dryer.
If your dryer does not have a removable rear panel you must open the top lid and remove the front panel.
Jan 16, 2010 | Kenmore Dryers
Kenmore Electric Dryer Model 110.6972110 timer motor NG
hi,
maybe call a generic appiance store other than sears, try maytag store. the knob pulls staight off and the timer nut is below. then take off the back cover off the control panel, sometimes those screws are on the front corners, sometimes hidden. take a picture of the timer wiring and tape and label all the wires before you remove it. unplug it first!!
jm
Nov 29, 2009 | Kenmore 62602 Electric Dryer
Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Feb 28, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
22 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
