Question about Sony KP-51HW40 51" Rear Projection Television
Tv double image
How do i adjust double image for my projection t.v
  • 4 more comments
  • Anonymous Feb 15, 2008
    Double picture RED & BLUE.
    Right And Left side of screen.
  • Anonymous Feb 16, 2008
    I have a sony kp-46-wt500 and it is showing double images. Whatever is on the tv is duplicated 2 inches to the right in red, and 2 inches to the left in blue. I took off the front cover and adjusted the focus--didn't help. I then adjusted the color or convergence dials--still no help. Can anyone please help me with this problem.
  • B-Clipper Feb 16, 2008
    I have a sony kp-46-wt500 rear projection tv. It is giving me multiple images. whatever is on the screen is duplicated 2 inches to the right in red and 2 inches to left in blue. I took the front cover off and adjusted the focus and convergace but no help. Does anyone know what is wrong and how I can fix it? Please help me!!!!!!
  • billiemalvin Jun 23, 2008
    philips 51 hd tv double words or color
  • rvmoo Sep 21, 2008
    I have double images but only the blue ones 2 inches to the left
  • Anonymous Mar 16, 2014
    hitachi projection color tv
  • 71 Answers
It's not only adjustment, you have to replace both STK 392-560 IC.
Posted on Dec 06, 2007
  • 84 Answers
SOURCE: Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
Posted on Feb 18, 2008
  • 4402 Answers
SOURCE: Projection TV Convergence
they have inherent problems with the glycol oil used to cool the tube leaking past the bladders & onto the boards.... & it's conductive :p
Posted on Dec 11, 2007
  • 121 Answers
SOURCE: getting "red" double image
you have a convergence problem ,green ,blue should converge to make picture but red is slightly out off ...usually there is an adjustment on these sets check your manual..
Posted on Apr 27, 2009
  • 5138 Answers
SOURCE: I have a sony projection tv KP-46WT500 and have
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Posted on Aug 08, 2009
SD Tech
  • 14553 Answers
SOURCE: sony rear projection tv showing double
If you have a CONVERGENCE problem and it will not adjust---the two STK-392-150 Chips this set uses need to both be replaced and the set adjusted with the original remote control.
You can, if you are able to do the repair, buy a pair of chips for less than 14 dollars plus shipping on Ebay.
If you cannot do the repair--shop around your area--most shops are going to charge 300 or more for this kind of repair.
When you consider the cost of the parts--if you can do it or know someone who can--you can save the set and a lot of money--This repair can easily be done right in your home in about 1 hour--I know as I have done hundreds of them---did two today.
The chips (with the back off of the set) should be on two metal heat sinks on the board on the far left---they will be facing the front of the set.
All that is required to get at them is to remove all the plugs on that board and the screws that hold it in and tilt it up so the bottom of the board is in view---you unsolder both chips (about 18 pins each) and remove the 2 screws that hold each to a heat sink.
With 2 new chips you put heat sink compound on the back of each--it is a white grease to move heat quickly from the chip to the metal, and solder both chips in----put the board back down and all the plugs back(I usually mark all of them so I know where they go) and turn the set on and see what you have...
Most of the time this repairs the set--go into the customer menu and adjust the convergence and you are ready for another 5-8 years of life---this is the normal lifespan of these chips.
If you need assistance or have questions let me know--I am here to help people.
If this information helped you, rate this solution as I do this here for free.
Posted on Nov 08, 2009
The outer edges of my screen are showing double images ie I get blue and red images
Adjust the cross hairs on your TV. See menu setting for convergence. If this will not cure the have a bad convergence board!
Jan 07, 2010 | Zenith R57W46 57" Rear Projection...
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Need to adjust lens focus on all three projectors
If its a double image that sounds like convergence.
Apr 09, 2009 | RCA D52W23 52" HDTV CRT TV
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC'
order two STK392-570 good quality.....16 to 22.00 each
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Double image - not covergence
Nov 21, 2007 | Toshiba 42H83 42" Rear Projection...
Projection Tv Problem
some of these tvs have internal adjustments for everything including alignment which fixes the double image problem. if you remove the cover you will find a lot of little adjustment dials. you may find that they have symbols that show what the adjustment is for. if you want more info. email me at
Sep 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
1,435 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
