Question about Sharp MX2610N Printer
Why won't the fax work?
The fax always says the receiving number is busy. But, I know it isn't. Thanks.
Do you use DSL for you internet? You may need a phone line DSL filter. $2 at Radio Shack. It may have come with your DSL modem.
Posted on Sep 25, 2015
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Sharp Expert
  • 106 Answers
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
Posted on Jul 28, 2014
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have a bother FAX4100E . It is newly installed. I can receive faxes but when attempting to send, no dial tone is immediatley heard. The fax always gets a fast busy. It is on the same line as my old...
Hi.
Check and eventually replace the phone cable.
The fax machine must be connected using a two-conductor phone cable such as the cable pictured below at the left:
Dec 13, 2010 | Office Equipment & Supplies
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
Oct 03, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
No matter what number i fax to I always receive a fax busy message. I have tried different phone jacks throughtout the house. What can I do to correct this problem? Thanks in advance!
Check in the fax setup menu and make sure that the setting for tone or pulse is set correctly for your area, most all systems now are set for tone dialing. Make sure you input the number just as you would dial it, like 1 before the area code and no area code if you are faxing a local number...
Aug 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Sharp MX2610N Printer Logo
155 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
