Question about Emerson Kitchen Appliances - Others
Where can I find a manual for Emerson 2 slice toaster, model EP93439?
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
SOURCE: duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Posted on Nov 05, 2007
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
Richie_asg1
  • 1036 Answers
SOURCE: the locking mechanism in our
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Posted on Jun 25, 2008
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
Where can I get operating instructions for the Tefal 5327-16 four slice electric toaster?
Hi there.
I have seen an Avante Deluxe 4-Slice Toaster Owner's Manual at http://www.t-falusa.com
You can download this if it matches the model of your toaster.
Regards.
Jul 18, 2011 | Kitchen Appliances - Others
The timer on my dualit toaster works and then
Unfortunatly this a very popular problem with the timers and the only solution is to replace the timer knob complete.
Their are in ebay and amzon com, very good price and they wll arive to you in a couple of days.
Mar 24, 2010 | Dualit 20247 2-Slice Toaster
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
ok...
When:
Where:
How:
WARNING:
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Emerson Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerson Kitchen Appliances - Other Expert? Answer questions, earn points and help others
