Question about Health & Beauty
Tyre Pressure for Moveck SI scooter
I want to check my tyre pressure but I don't know what is should be, any help?
SOURCE: tyre air pressure
factory recommended 2.3 kgf/cm² (32.7 PSI)
Posted on Oct 27, 2008
FitzOriginal
  • 842 Answers
SOURCE: Tyre Pressure
As always, correct pressure depends on the tyre fitted but if it is running with the standard tyres that it had fitted from new then:
Single rider: Front is 1.75 bar (25 PSI) Rear 2.0 (29 PSI)
Fully loaded (Panniers and or pillion passenger) Front 2.0 bar (29 PSI) Rear 2.25 bar (32 PSI)
These settings from the book for a 2006 model, though I imagine that they apply to all with very little if any variation
Posted on Jan 23, 2009
bunnydawg
  • 5158 Answers
SOURCE: What is the correct tyre pressure for a small Nissan Lucino?
should be a sticker on the door jamb on either the drivers or passenger side door that gives you that information
Posted on Apr 14, 2009
  • 11 Answers
SOURCE: Flat tyres and no manual - new scooter user
You can use the tire pump or an electric one. You can find the user manual for your scooter on www.shoprider.com click on the user manuals tab and find your scooter to download (pdf file) I think you have the Sprinter 3 Deluxe model.
Posted on Apr 17, 2009
AnIdea
  • 33 Answers
SOURCE: run flat tyre warning light is on i have checked tyre pressure
This will only come on when a tyre has dropped in pressure (not spare). It work on the principle that a tyre with less air has a smaller rolling circumference and therefore a different wheel speed. This is then monitored against other signals from other wheels and determined that a loss in pressure has occured.
If all tyre pressures seem ok, there could be a chance of a small unoticeable leak and would require a bath test. This is when the tyre is dipped in water and bubbles would appear where the puncture is.
Ultimately the system may just need to be reset, or has incorrectly been reset from a tyre change. For this you just press and hold the TPC button (located on the centre console above the gearstick - looks like a flat tyre with an exclamation) turn on the ignition to position 2 and the light will come on re then yellow,go out, come back on yellow. When it comes back on yellow it re-initializing the system. You can let go of the button and after 20 odd seconds the light will go out for the final time, completing the reset.
If the light continues to come on after the reset then you definitely have a puncture somewhere!
Hope this helps!
Posted on May 28, 2009
What's the tyre pressure for a caravan with 185r14c on it
It depends upon the type of tyre, whether you have a single or dual axle as well as the weight of the van when loaded.
The maximum tyre pressure for the type of tyre you have will be listed on the sidewall of the tyre. Given the weight of a loaded caravan I would recommend you run the tyres at 2 PSI under the maximum pressure listed on the tyre for a cold inflation. If the maximum is, say, 40 psi then run the tyre at 38 psi. Tyre pressures will increase when the tyres are warmed up from running so always check and adjust the pressures when cold and purchase a good tyre gauge to carry with you if you do not have one yet. Higher tyre pressures within max specification, will lower the tyre's rolling resistance and tyre heat build up, places less stress on the tow vehicle and will give better tyre life on the van tyres.
Tyres are maximum load rated so know the van weight and make sure you do not exceed the load limits of the tyres (printed on the side wall) when adding weight to the van, including water storage.
Tyre Sidewall Explained
Jun 06, 2016 | Cars & Trucks
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
Tyre pressure
You should find it marked on the wheel and or around a tyre valve. If you have standard tyres and tubes check your not very useful Pride instruction book.
Apr 18, 2014 | Pride Celebrity Xl 4 Wheel Scooter
I have a flat tire on my scooter which i would like to fix but unable to get the rim apart can you help me
Yes. Be careful! Only remove the wheel's central nut, NOT the outer ring of nuts yet. Remove the tyre valve slowly and with care to empty the inner tube. Remove the wheel by tapping the rear of the wheel as necessary - be careful to remove the axle key and keep it safely to one side. Remove the remaining wheel nuts split the wheel and remove the tube from the tyre and wheel. Check the wheel inner surfaces for rough spots and clean. Insert the new tube and making sure that nothing is pinched reassemble the wheel inflate the tyre to the recommended pressure in stages gently bounce the wheel once or twice to help the tyre to seat properly. Inflate to just above the recommended pressure and release surplus air. Offer the wheel up to the axle with the wheel and axle key slots exactly opposite each other. Insert the "key" in the slot and gently hammer it home.
Voila, you have done it!
Jul 30, 2013 | Pride Health & Beauty
I have aflat tire on my scooter that i would like to fix but i cannot get the rim apart the nut just will not move
Jul 30, 2013 | Pride Celebrity X 4-Wheel Electric Scooter...
Tyre pressure of bajaj platina
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Checking your scooters tire pressure
Honda CBF 125 Tire Pressure Check
Bajaj Platina 125 DTS Si 2010 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.marutibajaj.com/pdf/platina125-jk-block-2010.pdf
Bajaj Platina 125 5 Speed
Jun 14, 2013 | 2011 Bajaj Platina 125 Dumdar Sawari
What tyre pressure
tyre pressure is the pressure which is inside the tyre
Mar 25, 2011 | Health & Beauty
Whats the correct tyre pressure for my 2001 suzuki burgman an 400 also if by chance i had put 4 bar in the tyre by mistake but only had the scooter on the centre stand have i done any harm
Hi, a 1999-2003 suzuki burgman /an 400 using standard tyre sizes 110/90-13 front is 1'75 bar (25psi)
130/70-13 rear is. 2 bar-(29psi) and 2.8 bar (41psi when carrying a passenger) check the tyre for correct seating on the rim, dont think you have done any harm, the only danger inflating small tyres to a high pressure is you risk blowing it off the rim, as you have now corrected it you should be ok with that, paul
Feb 21, 2011 | 2001 Suzuki AN 400 Burgman
What are the tyre pressure in psi for 650 nt deauville
turn the gage around or somethin. It should be on their if not go get a new guage. And if you do not know what the psi should be at look on the tire. And dont put the psi to the max. if it says 35psi put like 32psi just leave a few pounds off the max psi
Apr 03, 2010 | 2001 Honda Deauville NTV 650
I want to know the tyre pressure front and rear daytona 1200
Yup nice question. For any vehicle accurate tyre pressure will give you better tyre life, low running cost, etc. Here is a chart for car tyres click here.
For bikes i havent found any chart. basically in india rear tyres having 100/90 18inch maximum tyre pressure is 32psi. front tyre having 2.75P or 80/90 18 inch uses 24 psi pressure. and do check your tyre pressure twice a month.
Dec 12, 2009 | 1995 Triumph Daytona 1200
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
