Question about Omnitech Office Equipment & Supplies
Is there a reset button on model OT-NXC18PA - Omnitech Office Equipment & Supplies
Omnitech shredder ot-nxc18pa won't power up
Dear Bruce,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that senses if the paper has been introduced to the shredding slot.
These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing.
While disconnected from the power, try to check if the switch is working properly. Check if you can hear a "click noise" while moving it back and forth by using a paper clip. When this sensor arm is broken, the device will not operate since it does not detect the presence of a paper sheet to be shredded.
Make sure your power is on (not only connected to the wall - but check if there is any indicator in the shredder). If the arm is not broken and you still hear the click noise indicating the micro switch is being activated, then your problem could still be the power since there is not LED indicator in the panel of this device.
If this does not solve your investigation process, please make sure your power cord is fine. Otherwise, it would be an internal electric problem in the device.
One additional possibility (since I have no further details from you) is that the device is on, you can hear the motor running but the gears that move the shredder blades are broken (that has happened to my device).
I hope this gives you some light in further investigating your problem.
RC
Mar 22, 2014 | Omnitech 10-Sheet Micro-Cut Shredder
Alcatel 282 displays SIM LOCKED SOS only. How do I rectify this problem
The solution is to hard reset the Alcatel OT 282 by the following key combination, note that it will remove all your data and customization on the phone:
1- Turn off your phone.
2- press # and hold while you turn on the phone with the on/off switch "for the OT 282 it is the hang up red button".
3- The phone will ask you to reset and lose all data, press Yes.
4- Voila! phone works again.
I had the same phone with the same problem and the above solution worked like a charm to restore access to normal phone functionality.
Feb 12, 2013 | Cell Phones
How to master reset emerson 4.3 " internet tablet model em543
When i do this a green monster shows with the door open to his stomach with a red sign on ot what does this mean??
Jan 05, 2013 | Tablets & eReaders
Is there a sensor for Omnitech shredder OT-NXC18PA? if so where can I locate it?
I have this same shredder and same thing happened to mine just 2 months after warranty is up. I called the company and told the sensor is gone and there is no way to replace. BTW mine runs in reverse but not forward.
Jun 24, 2012 | Tech Solution Office Equipment & Supplies
Phone wont turn on or charge
is it an iphone? if so hold down the button ot top for 15-20 sec while holding menu button simutaneously to do master reset
Jun 10, 2012 | Samsung Admire SCH
I forgot the phone code of alcatel OT-E230 imei 35231501140515 what is solution...?
if you forgot the security code then you can try with master reset codes and reset your mobile and for your mobile model try simpleunlocking to get master reset codes..
Jul 23, 2011 | AT&T Lands Phones
Ive got a alcatel ot-708 that i whant to change network but need network key
You have to reset the phone. Take out the battery thehold the UP volume key at the same time as the power on/off button. WHen asked if you want to reset the phone you click the volume UP key. You will lose everything in the phone memory unfortunately but not sim card.
Nov 28, 2010 | Alcatel OT-C701 Cellular Phone
Replaced lamp-orange lights still flash.....lame!
Yes, Turn On TV, press and hold Volume Down button on TV front and Split button on remote at same time for 6 seconds to reset lamp timer in TV.
Sep 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Monitor Reset Instructions
it is a setting button problem. pls checked this button.
Aug 31, 2009 | Canon Pixma MP450 All-In-One InkJet...
94 people viewed this question
Top Omnitech Office Equipment & Supplies Experts
ray gallant
Are you an Omnitech Office Equipment and Supply Expert? Answer questions, earn points and help others
