Question about Dinosaur Imaginext Spike The Ultra Dinosaur Junior
I need LH130-2A51MC8HROT 9.6 V AA SIZE
Where can I buy this battery?
I need a battery for my Model 840 Healthometer scale. Date on back Dec 15 02.What size battery fits as I don't have the old one.My battery place doesn't have one.
the hole for the battery will give you the clue
if it has a single groove with a spring at one end it will be either AAA or AA battery ( depending on the groove width
2 grooves will again be AAA or AA battery
a square hole with the terminals together in a plastic cap will be a 9 volt battery
a round hole with a metal finger will be a button battery possible a 2063 size
the owners manual will have the right battery listed or it will be listed on line in the manufacturers specifications for that model
Jul 15, 2017 | Healthometer Health & Beauty
Tip
Olympus E-10/20
I have been on love with my Olympus e-20n since the day I bought it. Yes, it's only 5 mega-pixel but the SLR design and full manual functions out weigh the limited resolution. I was very disappointed when I tried to buy a replacement high capacity battery and Lithium Polymer 8400ah battery was not only discontinued but totally not available (except for some used ones on Ebay and I'm just not brave enough to buy a used battery)
So crafting a replacement became my Memorial Day Weekend project. One quick trip to Fry's Electronics later and I had the solution. A 6-cell AA battery holder, 6ea AA NiMH 2600ah rechangeables and a 9-volt battery clip with pig tail is all I needed.
Crack open the external battery add-on (looks like a power winder on a 35mm SLR) 4-screws on the botton, one inside the battery well and 2 under the rubber hand grip. Locate the battery connector and un-screw the RED and BLACK prime power leads from each side. Cover the connector with electric tape or an insulated cover, your done with it, forever.
Solder the pigtail 9-volt battery clip to the RED and BLACK leads (red to red and black to black, duh!). Extend the 9v battery clip outside the case and re-assemble the case.
The 6 AA-cell battery holder will fit nicely into the battery door cup and if you pack the vacant space in the battery well with sponge or an old gym sock the battery will not slide around.
Fill the AA battery holder with the rechargeable batteries you have freshly re-charged and hook up the 9v clip. Thats it, new life for the my old companion.
on May 31, 2010 | Cameras
Difference between lithium battery and AA size battery for camera
"Lithium" refers to the chemical makeup of the battery. "AA" refers to the size of the battery. There are such things as lithium AA batteries.
If your camera takes AA batteries then lithiums will give you more shots than other types. They will also cost more.
Oct 06, 2014 | Nikon COOLPIX Cameras
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
What is the best battery to use in my digital camera?
Every camera only takes a certain type of batteries for instance, my polaroid takes two double AA batteries.
Jan 15, 2011 | Canon PowerShot SX130 IS Digital Camera
I need a new battery for the remote, and I do not know which battery I need. (I can't see anywhere in the manual where it lists the size of battery to buy)
99% of all remotes today have either AA or AAA batteries. If you remover the battery cover the size is normally printed inside and on the batteries if they are there.
Dec 07, 2010 | Televison & Video
Are the batteries fo Powershot A85 rechargeable
This camera takes ordinary AA batteries. You can use alkaline ones, which are mostly not rechargeable, or you can use a set of AA size NiMH rechargeable ones, which will last longer per charge than a set of alkalines. You will need a separate charger for the batteries, they won't charge in the camera. You can buy a charger complete with a set of batteries cheaply online or in shops. Get ones marked 2300 mAH or 2700 mAH if you can- they will last longer than ones with lower ratings.
Oct 18, 2010 | Canon PowerShot A85 Digital Camera
Weird battery size
use the AA batteries thats what i use and it still comes in and out
May 04, 2008 | Directv RC32RFK Remote Control
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Dinosaur Imaginext Spike The Ultra Dinosaur Junior Logo
191 people viewed this question
Top Dinosaur Toys Experts
ray gallant
Are you a Dinosaur Toy Expert? Answer questions, earn points and help others
