Question about Clark Forklift Horn Button Switch , Cat Etc
Ecg 30 clark forklift error code -90 what does it
3 Suggested Answers
  • 9 Answers
SOURCE: tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
Posted on Jan 24, 2011
ftw1952
  • 10319 Answers
SOURCE: clark forklift with error code
The description for code 15 is battery voltage to low. The code will flash when the battery volts are less than 1.95 volts per cell when the key is turned ON. Check the battery voltage with volt meter at battery were positive and negative connect. If the battery is 36 volt it should be no less than 35.1 volts, if the battery is 48 volt it should be no less than 46.8 volts. If battery voltage is low check each cell indavidually to locate a bad cell, each cell should have around 1.95 volts, if a couple are dramatically lower that may be your problem. If the battery checks out check your cables and connections (this seems likely because you say its after you charge battery, when you plug and unplug your battery in you wiggle the cables around witch could cause a poor connection.) Check over your cables carefully as corosion can grow inside of them especially near the battery and connector. Hopefully this helps, looking forward to positive feedback thanks.
Posted on Aug 25, 2011
How to change horn on clark gcs15 forklift
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Clark GCS GPS Standard Forklift Factory Service Repair Workshop Manual...
Jun 13, 2017 | Clark Electrical Supplies
Forklift Clark ECG25 error code -7
I'm sorry, I don't quite understand your question. You have posted it in the wrong section; please find the correct one.
Jun 27, 2014 | Electrical Supplies
Tm 20 clark forklift error code -46 what does it
Jun 21, 2010 | Clark Forklift Horn Button Switch , Cat...
Problem with Clark forklift TMX12-25 TMX250, red spanner warning lights come up. whats that mean, how to reset it
It means it's time for your periodic maintenance, the reset button should be close to hour meter
Feb 01, 2010 | Clark Forklift Horn Button Switch , Cat...
Why does my clark forklift lower by it self
it has bypass in the cylinders you need to rebuild it[put new seals in it].
Dec 21, 2009 | Clark Forklift Horn Button Switch , Cat...
Clark Forklift GPX25 will not shift into reverse. Unit was working fine a month ago. Do not use the forklift that often about once or twice a month. Unit will work in forward, but not reverse. Even when...
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
Oct 03, 2009 | Clark Forklift Horn Button Switch , Cat...
Clark Forklift Horn Button Switch  , Cat Etc Logo
Top Clark Electrical Supplies Experts
Bill Boyd
Fred Sops
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
