Question about NetGear WGT624 Wireless Router
I can't remember the password for my router. I just got a laptop and want to use it wirelessly but I cant gain access to my network.
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    hold the reset button for 10 seconds this will cause it to go to factory default. so you can access it and reconfigure it
  • 121 Answers
Hi
In your case you have to go to your service provider for more free technical you can visit---http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Posted on Jun 22, 2009
  • 854 Answers
By default
username: admin
password: is password
if not...try hard resetting the router, use pin to poke the reset button at the back of the router then follow this steps;
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
3 Suggested Answers
rustysheriff
  • 344 Answers
SOURCE: cant remember my password to gain access to my router to gain internet.
Should be a tiny button on back, you might need a pencil to press it, just press and hold for about 10 seconds to reset to factory settings
Posted on May 27, 2009
  • 161 Answers
usually username: admin or try superuser password: password
Posted on Jun 01, 2009
How to secure my home network wifi how to put a password?! it appears that it's Unlocked..
Wireless network passwording is done at the router, in the wireless setup area. Log into your router using the admin userid and password. Go to wireless settings and there you will see the option to set a password for the wireless network. One you set the password and save it, all devices that connect to your network wirelessly will need to be reconnected to the network, using the password you selected to gain access to the network.
Sep 17, 2016 | SENAO High Power 200mW USB WiFi 802.11bg...
I currently have the product below, but is connected to a unsecured network. How do I get it to where the network I am connected to is secured. thanks for your help.
Start your web browser and in the address bar type 192.168.1.1 a window will appear and ask for a username and password. leave the username blank and type ADMIN in the password. This should gain you access to the router settings. Just look at the top tool bar for "WIRELESS". Then click on wireless security. Once there you can change the name of your network ffrom LYNKSYS to a name of your choosing. Also you can set a passcode. For basic security use the WPA personal and TKIP password. You need to choose a "passphrase" and you will have to enter it to connect to the nertwork. make sure to SAVE CHANGES. You can also change the password to gain access to the router (the 192.168.192 part). IF YOU DO make sure you can remember it.
Once all the settings are in place, any device trying to connect to your network will be required to enter the pass phrase EXACTLEY as you entered it in the router settings. You should only have to do it the first time.
Feb 04, 2011 | Linksys Wireless-G WRT54G Router
Can't remember wi-fi password
hi spues,
If you cant remember the Network Key you can access the Wireless Router Page so that you can obtain the information and you can personlize it aswell. To access the router page just open a browser then type http://192.168.1.1. the username is admin and the password is password. Go to the Router Settings Page. Look for the Network Key. Personalize the information so that you can easily remember it.
Rate me if this helps so i can help others.
Thanks for using Fixya.
Jan 31, 2011 | NetGear WGR614 Wireless Router
Lost password. Have a Belkin 2.4GHz - 802.11g Wireless. Have had this some time and after spilling tea on my laptop have had to get another - however cant remember password to get me back on wireless...
Connect an Ethernet cable from the network port on your computer to one of the LAN ports on your router.
Start Internet Explorer.
Access the web-server inside the router: http://192.168.0.1 or http://192.168.1.1
and set a new password for your wireless network.
Jun 09, 2010 | Belkin (F5D7633UK4A) Wireless Router
Have forgotten NetKey password to add laptop to wireless network
Just reset the router and you can configure it again like before.
Jul 01, 2009 | Linksys Wireless-G WRT54G Router
Cant remember my password to gain access to my router to gain internet.
May 27, 2009 | Linksys Wireless-G WRT54G Router
CONNECTING A LAPTOP THROUGH THE ROUTER
Please check for any firewall or Antivirus on your computer. Try disabling the them.. Kindly let me know the Make of your laptop & are you using the Windows utility or any brand specific like Dell or HP wireless assistant.
If you are using any one of those than try the following steps:
1. Go to Control panel- Network connections- Right CLick WLAn connection- properties- Select windows zero configuration utility
Feb 03, 2009 | Linksys Wireless-G WRT54G Router
How to get password key
WEP password is on botom or on the side of the router
Dec 13, 2008 | Belkin (F5D7231-4) Wireless Router
I bought a 2Wire gateway router / modem.
type ur IP address on ur address bar 192.168.1.254
and go to ur firewall and then advanced settings
go to the bottom and allow all application
that should do the trick !
if you cant remember ur system key click forgot password should give you a hint if that dosnt work try still cant remember password
Dec 01, 2008 | 2wire (1000-400108-001) Router
NetGear WGT624 Wireless Router Logo
1,799 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
