Question about Whirlpool Duet GHW9150P Front Load Washer
My Duet washer starts and runs for few seconds, then stops.
My Duet washer starts and runs for few seconds, then it stops, all lights are off, no errors on the panel, door is locked. I've been trying to start it several times and got the same behaviour.
    President:
  • 744 Answers
Unplug machine take small panel off on bottom front of your washer, there should be a twist knob on pump, unscrew this (bearing in mind water will come out) you will find a strainer that catches debris before going through pump, clean out debris and re-intall. plug machine back in and try again.
Posted on Jun 22, 2009
F8 error code Whirlpool Duet
see this causes and fix it. See yur section troubleshooting in your owner manual, or call some tech.
F8 Board failure Replace control board (also called ERC or clock).
Sep 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer runs all the time drain fliter is clean
check pcb, drain pump releated traic check it could be faulty
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stopped during wash cycle.
UNPLUG THE WASHER AND TAKE THE 3 SCREWS THAT ARE ON THE BACK OF THE WASHER OUT AND REMOVE THE TOP PANEL OF THE WASHER. CAREFULLY UNPLUG AND REPLUG IN THE WIRING SO THAT U WONT GET THEM MIXED UP. DO ALL OF THEM, FIRMLY BUT GENTLY. THEN HOLD IN THE SIGNAL CYLCE LITE FOR 3 SECONDS. TRY TO RUN A LOAD AND SEE IF THAT WORKS. IT DID FOR US, SO FAR SO GOOD. GOOD LUCK!!
May 30, 2009 | Whirlpool Washing Machines
Control locked
should be a small button on the left at the bottom of the controls, should say to hold it for a few seconds to unlock i know this because i did the same thing good luck
Mar 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
196 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
