Question about LG WT4801CW 3.7 cu. ft. top load washer
Lg WT4801CW top-loader does not wash in hot water
Washer is about 2 years old. Used to be able to wash in hot water, now the temp of hot water is 82 degrees, at most, sometimes colder.
  • 1462 Answers
SOURCE: LG WFT1022TP top loader washing machine
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off. the things to look for are: gunge in the air chamber split in the pipe. faulty pressure stat to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
Posted on Apr 02, 2007
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
SOURCE: my lg top loader washer continously drains water and never washes
I was solve resolvbe it in a most simple way.
Posted on Jan 31, 2010
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
  • 330 Answers
SOURCE: Our LG Tromm front loader
the draiin pump is blocked or failed & needs to be replaced.
Posted on Jan 11, 2011
Lg top load washer 1 year old, vibrates violently during spin. Checked an adjusted level, no help.
they have springs and shock absorbers in the machine to help stabilize the load when spinning. since the washer is so new, i would guess one or the other has just come loose. take top off and check. online videos will show you how
Feb 24, 2016 | LG WT4801CW Top Load Washers
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
I have a Top Loader LG WT4801CW Washing Machine. Nothing comes on!
Hi, you could try locating the water filter and checking & cleaning it out plus shine a torch down the hole to check for any objects stuck in the pump blades such as hairclips, coins etc. Make sure you have a tray/container /towels etc beneath the filter opening to catch the water and use the drain tube first (if supplied) to drain water slowly into your container. If that's not it, try checking the drain tube and drain itself for any blockages. Good luck from England!
Jun 20, 2014 | LG WM-2277HW Front Load Washer
LG WT4801CW HE top load washer poor performance.
I think you will find that hair and lint is much more effectively removed in a dryer.
Mar 23, 2017 | LG WT4801CW 3.7 cu. ft. top load washer
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Jun 06, 2009 | LG WM0642H
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Make sure you are washing at the correct temp, and that you have the correct prog selected for what you are washing. and that you have suficient powder and or detergent in. Check to see if the water is getting hot, because if it is not , then the heater may not be working, and then your clothes will not be clean.
Hope this helps with your prob.
Plz rate my solution.
Thanks.
Jan 03, 2009 | LG WM-2277HW Front Load Washer
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WT4801CW 3.7 cu. ft. top load washer Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
