Question about CenDyne Computers & Internet
How do i get my cendyne bluetooth usb adapter to work?
Want to Bluetooth music from iPhone to 2011 gmc Yukon. Will simple USB dongle work?
Yes this is possible but the Bluetooth adapter must have compatible drivers loaded.....unlike computers you can't load a suitable driver! You will have to trial and error different makes and see if it works!
Mar 29, 2014 | GMC Yukon XL Cars & Trucks
Missing driver
In general XP does not need drivers for thumb drives.
You can try use it on a different computer and format it there.
Also sometimes the drive does NOT show up because there is an
drive letter issue. You can see that in Control panel - Administrative tools - Computer management - Disc management and there it should show up..change drive letter and :-)
Oct 26, 2013 | CenDyne 16GB USB 2.0 Flash Drive (Black)...
How do i turn bluetooth on on my laptop
Bluetooth works off the wireless. If your wireless switch is on, then the bluetooth will be activated. If you don't have a bluetooth installed you can buy a bluetooth usb adapter from Tiger Direct.
http://www.tigerdirect.com
When the site comes up just type in the search box at the top of the page: USB Bluetooth Adapter and click GO.
May 23, 2012 | Computers & Internet
Cannot use my cendyne 16 g usb flash
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps
May 16, 2012 | CenDyne 16GB USB 2.0 Flash Drive (Black)...
Wher can i buy a usb reciever for my wireless keyboard
Normally all wireless keyboards work with Bluetooth protocol.
Pls check it in your keyboard's specifications.
If it's so, then you can just buy a USB bluetooth adapter costing around 5$.
e.g. from ebay:
http://shop.ebay.com/i.html?_nkw=bluetooth+usb+adapter+mac&_sacat=0&_stpos=&_sop=15&gbr=1&_odkw=bluetooth+usb+adapter+keyboard&_osacat=0&_trksid=p3286.c0.m270.l1313
Aug 02, 2011 | Computers & Internet
I dont a cd drive is it possible to down load a the information online so that my bluetooth micro adapter micro 2.1 usb can work.............
http://www.iogear.com/support/dm/driver/GBU211#display
or
http://drivers.softpedia.com/progDownload/IOGear-USB-Adapter-with-Bluetooth-wireless-technology-GBU211-Driver-10-Download-21387.html
here is the manual
http://www.iogear.com/support/manual/GBU211-GBU311%20Manual.pdf
Aug 21, 2010 | IOGear (GBU211) Bluetooth Wireless Adapter
Where can I get a power adapter for model CDICD00175 COMPAC DISK
www.LaptopACAdapter.com/Adapters Try that and do a search on your model number.
Nov 09, 2009 | CenDyne (CDICD00153) DVD-RW Burner
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Troy Windconnect printserver has stopped working
Due to tolerances in manufacturing, some Bluetooth-adapters/receivers do not stick to the Bluetooth-standards exactly. If this only applies for one adapter/receiver in a pair everything works fine nevertheless. But if both do not stick to the standard, they might not be able to work together, although both would work with a standard-conform third one.
Before your mainboard was replaced, only your printserver was not exactly standard-conform. Now with a new mainboard (and therfore a new Bluetooth-adapter on it) just by accident your Bluetooth-adapter does not confirm to the standard, too.
If all this is right in your case, the solution would be to buy a Bluetooth-usb-dongle for your notebook and use this instead of the built-in Bluetooth-adapter of your notebook. If this new Bluetooth-usb-dongle confirms to the Bluetooth-standards better than your built-in adapter, this might cure the problem. Since such a Bluetooth-usb-dongle only costs about 10 Dollars, it might be worth a try.
Greetings, Michael
Feb 23, 2009 | Troy WindConnect With WindPort PC Card...
Driver for bluetooth for win 98
Hi!
1 Was it working before?
2. Is the bluetooth compatible with Win98? Does it meet the bluetooth's minimum requirements?
3. Is your computer an old computer? Maybe your computer's USB ports are USB 1.0 and the 4Gb USB is USB2.0. This I believe will be incompatibile.
4. Try those USB adapters at a different computer to further isolate your problem.
Hope these info helps!
May 01, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Computers & Internet Logo
51 people viewed this question
Top CenDyne Computers & Internet Experts
David Payne
David Payne
Are you a CenDyne Computer and Internet Expert? Answer questions, earn points and help others
