Question about Leviton Rotary Dimmer 6683-i Ivory 3-way Trimatron
Leviton 6683 manual? - Leviton Rotary Dimmer 6683-i Ivory 3-way Trimatron
TWO BLACK WIRE COMING FROM THE WALL ONLY DIMMER SWITCH LIGHT WONT GO UP AND DOWN
You are trying to connect a three-way dimmer in place of a single pole switch
Jul 02, 2013 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
HAVE A DIMMER BUT THE WALL HAS TWO BLACK WIRE ONLY
Suggest buy duy dimmer that does not need neutral wire, and will only work with incandescent bulbs.
Or violate code and use ground wire as neutral.
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
Jul 01, 2013 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
Leviton dimmer
Your product is not identified by number given.
Leviton posts manuals online by searching Leviton xxxx .pdf.
There is a CPT 602 lighting console
However no result shows online or at Leviton for a 602 dimmer
Contact Leviton:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37579&minisite=10251
Add a comment and attach photo or video for possible identification
May 27, 2013 | Leviton Electrical Supplies
Change program leviton timer
Copy following link to identify Leviton timer and download manual
http://waterheatertimer.org/Leviton-timers-and-manuals.html
May 02, 2012 | Leviton 1000W / 20A 1HP-120V - 6230M-A -...
Dimmer does not work
A 3-way light switch needs 3 wires for both switches to work correctly. If there is only 2 wires on the switch, its not a 3-way. Only two black wires on the switch means it can be wired either way. The power and light leads are inter changeable. If you really need a 3-way switch, be sure it is labeled as that on the box and look for 3 connections on the switch its self. Else, try a switch rated for a higher amperage.
Nov 30, 2011 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
Two black wires come to original switch. I have wired the dimmer turning the wires around and the switch will not work. What did I do wrong?
If the picture is accurate, I have had the same misfortune with this model. Two wires the same color means its not pole sensitive and can be wired either way. Replace it with a more expensive switch and you should be OK.
House has 2 blue wires and one black.. this switch is one of 2 that controls the hall light. my switch i am installing has 1 black 2 red and the green ground. which red goes with which blue wire..
At this point either. Once you hook up the switch test the switches on both sides. Make sure each one turns on and off if that makes sense. If the blue wires are on wrong one switch will only work if the other one is on. If that happens reverse the blue wires and that should fix it.
May 30, 2011 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
Need instructions to set my timer. Where can I find these?
You posted under Leviton 6124
If this is not your timer, add a comment.
Also see Leviton timers at:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 manual
http://waterheatertimer.org/images/6124-manual.pdf
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
I have a black wire a white wire and a ground
The red wire is your chase wire and needs to go all the way to the other switch
Mar 07, 2010 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
Leviton Rotary Dimmer 6683-i Ivory 3-way Trimatron Logo
97 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
