Question about Dometic RM2652 Refrigerator
Does n ot appear to be getting power to the main terminal block
    Top Expert:
  • Dometic Master
  • 5,673 Answers
If power before check that if after board bad board
Posted on May 25, 2016
Have a Balboa Hydra pool spa model #du-hp-the power comes on power to the fuse and all it does is click when you press the Jets or light like a tick fuse is blown on top 1
Balboa Hydra pak?
The problem you stated is not clear.
Check for proper voltage to the main terminal block. You should get 240, reading across both the line terminals, not one to L1 and the other to ground. Across both hots. If you have only a 120 volt system then make sure you have 120 at the terminal block.
Your comment "I have power at..." is very vague. How do you know you have "Proper" power?
Replace any bad fuses with like.
Good luck
Nov 06, 2014 | Pool & Spa
TV keeps coming on and shutting off
Hello
Its voltage switching section has the trouble. The voltage from it to the main board and LOT section is lower than normal. It is actually working, but output voltage sensor section have the fault. Normally this faule may due to some loose soldering points in the power switching section. The power switching components will heat up while working, and repeated heating and cooling make the soler terminals of high watt resistors and other switching components ot get loose contacted. These loose soldering are very difficut to identify, because they will be microscopic, and cannot detected. To do is, resolder all the suspected solder terminals by applying a little more solder; without making any short circuit between adjecent solder terminals. Pull out the main board out; after unplug the set from AC mains power socket. Tirn it upside down, and locate the power switching section, resolder as stated earlier. If this does not solve the problem of your TV, power switching components should be checked and the faulty ones must be replaced. OK.
Jul 14, 2011 | RCA TruFlat 27F520T 27" TV
No charge /alt good/ new computer/ was told at auto parts site(auto zone) that defective crank position sensor could be problem
Hi, No the crank angle sensor is not the problem. Check that there is power to the main battery terminal on the alternator and that there is an ignition supply to the small terminal block attached to the back of the alternator. If these are ok then it maybe the light switching terminal or the battery sensed terminal which is also in the terminal block in the back of the alternator.
Last and not least get the battery checked that it is ok...
Jan 24, 2011 | 1992 Plymouth Grand Voyager
When we turn the dryer on it seems like it will run but stops and gives us a e9e code where the time should be. Model number AEQ7000ES1
Hi and welcome to FixYa, I am Kelly. After reading the service manual, the E9e code is a line voltage problem. It is cause by low voltage or intermittent voltage. This could be a loose connection in the dryer plug or at the terminal block. There can also be a problem with a hot terminal connection cause by a loose terminal. It can also be a problem with your local utility power. Voltge has dropped below 215VAC to cause this code to appear. My suspicions are a loose / hot connection either at the wall connection or dryer terminal block. You may have to replace the dryer cord or receptacle. Possibly even replace the terminal block if it has been damaged. You should also check to see that your main CB for the dryer is properly seated in the power panel. If it is not seated correctly it can also cause this symptom. Press the CB to OFF by physically pushing it to the OFF position and then back to ON. By doing so you did a complete reset of both CB power connections internally. Press hard on the face of the CB with your thumb to make sure it is seated in the power panel. Pressing cancel should clear this fault after repairs have been completed.
The repair manual can be found here: Fault code is listed on page 16 of the link to the left. The terminal block connections are on pages 37 and 38. Just note there is a major difference between a 3 prong and 4 prong power cord connection. The terminal block ground is re-configured for a 4 pronged plug. If you have to replace the terminal block make a hand written diagram FIRST! Number the wires with marked masking tape if you have too. I am pretty certain that when you find the source of the low voltage problem your dryer will be fine. Currently it is reacting to low or intermittent input power.
Thanks for choosing FixYa,
Kelly
Dec 28, 2010 | Frigidaire Electric Dryer
Maytag electric Precision Touch 850, Clock and lights work everything turns on but stovetop and oven does not heat up oven was just used three days ago. It does not appear anything is locked per manual
check the main power at the terminal block and make sure you have the correct amount of power.just because the unit is lit up it may need to be changed.
Oct 20, 2010 | Maytag Kitchen Ranges
Why isnt anything digital working on my stove?
you need to check the main power terminal block and ensure there is proper power to the unit.if the power is correct at the terminal block then you will have to replace the main electronic control board
Oct 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire front load dryer won't turn on at all
check the main power and terminal block make sure there is power and no problems with the terminal block.
also a bad thermal fuse can cause a problem with the power check the thermal fuse and make sure they have continuity.the last thing to look at is the main control board these can cost up 150.00 dollars depending on where you get it.Bottm line yes i would say it is worth fixing
Jul 27, 2010 | Frigidaire Electric Dryer
Bought new timer for Prodigy but thought i set the wires from the old timer in proper sequence but doesnt work so maybe wrong wires on wrong terminals
Look at the wires. They have markings on them that match the markings on the timer. Did you check the Non-resetable limit? If it is open the dryer will not run.89819b0.jpg
More here
Jun 06, 2010 | GE DVL223EBWW Electric Dryer
What does message 'PF' signify after dryer stops in mid-cycle? Started a small load to dry, and after about 5 minutes, dryer stopped and message PF appeared in digital readout in the estimated time window
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Also check the thermal fuse and test it for continuity. A lack of continuity means a faulty fuse. Hope this helped and best wishes.
Sep 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Copier konica 7035 call service f-35-4
CAUSE: Incorrect AC wiring connections on the 4-pin fasten terminal block located in the rear of the fuser unit.
SOLUTION: Reconnect the AC wiring to the 4-pin fasten terminal block as follows:
While viewing the 4-pin fasten terminal block from the rear of the fuser:
RED wire from top lamp (L2), in the heat roller, is connected to the right front terminal.
BLACK wire from the bottom lamp (L3), in the heat roller, is connected to the left front terminal.
WHITE wire from the top rear position (closest to the web) of the main fuser connector CN13 is connected to the left rear terminal.
WHITE wire from the top front position of the main fuser connector CN13 is connected to the right rear terminal.
Feb 20, 2009 | Konica Minolta Office Equipment & Supplies
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
