Question about Brother MFC-7220 All-In-One Laser Printer
Unable to print display
Printer was worked on before made 1/2 copies now says unable to print
2 Suggested Answers
  • 286 Answers
SOURCE: error messages and print problem
There are a couple of things that can cause this fault.
The most common cause is a paper jam has occurred, and the user hasn't gotten all of the paper out.
Lift the lid, use a light to look into the left side of the head travel area. Make sure there is no crumpled paper. If not, carefully move the head all the way to the left and try to look at the right end of the head travel. Look for crumpled paper again.
If you cannot find any paper, the encoder strip may have become dislodged. You will have to take the machine apart. Open the lid, remove the wid=re civers with a small flat screwdriver. Remove the prop rod (blue piece holding the lid open). Unplug all the cables and unscrew the ground wire. Move the scanner off toward the rear.. Remove the rear cover. Unscrew all screws in the top cover assy. Hinge the control panel outward and remove carefully. inplug any attached cables. Use your scrrewdriver to unlatch the two tabs at the front and pull the upper case assy up and off. Look at the print head. There should be a plastic strip going from left to right that is seated in a sensor on top of the head. Make sure it is seated correctly. Remove any crumpled paper. Reassemble and test.
Posted on Nov 04, 2008
Printer does not print from computer
1) Unable to print from the computer and no error message is displayed or
2) Unable to print from the computer when an error message is displayed
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9722
Answers to both from Canon support: (copy and paste link into your browser). Type question 1 or 2 according to your situation. Click "Search". Review the solution(s).
Dec 05, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Unable to cop
You can not use the copy feature if your printer is "printing". You can scan while other is printing simply because scanning is not using the printer's print heads. Therefore if you are printing, you can not copy at the same time.
Is your printer printing OK? So you should be able to copy as well. Press COPY button when the printer is ready. Basically, you have the Copy (Black) and Copy Color options. If you have 1 option only, pressing COPY makes you choose black or COlor using the keypad selector. Just choose any option and press OK or START.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
Unable to store job at printer.
uncheck "MOPIER" in printer properties. Printer is mopy.
Jul 20, 2009 | HP LaserJet 5550 Printer
Printer unable to copy documents when used as a copier
go into control panel/printers, and make sure your printer is the default; as well, when your print screen is displayed make sure your printer is marked
Apr 07, 2009 | HP Photosmart C7280 Printer
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Feb 25, 2009 | HP LaserJet 2300L Printer
Unable to print mcf-215
plz press menu then start-bk-copy then fourtimes arrow up quickly after another. machine turns to maintanence mode. press start bk copy: what two digit error code does the machine display?
If it starts with a 4 you do need a new printhead!
Mar 28, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-7220 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
