Question about Refrigerators
My fridge Godrej pentacool gf21R does not form ice at all.
2 Suggested Answers
SOURCE: Godrej Pentacool Model No GF21 is not cooling
godrej pentacool get more moisture plaese solve this problem
Posted on Aug 18, 2010
Ice on coil in freezer
may be thermostat, need a professional
Feb 28, 2012 | Frigidaire Refrigerators
A layer of ice keeps forming in the bottom of the freezer. can chip it out and a new layer will start forming by the next day. also has a lot of frost as well. thuoght was the seal and have attempted to...
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
I HAVE A GODREJ PENTACOOL REFRIGERATOR. It is not cooling as much as it used to. The compressor is working, it is also warmer at both the sides, as it used to be. I would like to know at what point I am to...
Most times the coils are getting dirty and just need to be cleaned off. They are normally now days under the unit. You can get to them by removing a panel in the rear or by removing the front lower grill. Once you gain access just clean the lint/dust off. Compressed air will work best. Check out this video to assist. It seems to be of help.
http://www.youtube.com/watch?v=gXhDHk7xzww
Apr 24, 2011 | Refrigerators
The freezer is icing up again on my MSD2758GE fridge. How can I test to see if it the adaptive defrost assembly or something else?
Top of Form
Suspect the fault can be the defrost timer to confirm shut off the fridge, after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Maytag MSD2758GEB Side by Side...
There is compressor sound problem in godrej pentacool refrigeratore
Im taking that you have a fridge that works fine you just have a noise that is bothersome. The easiest way to correct vibration noises is by pushing on the compressor or surrounding coils until you find the offening spot of vibration. You can buy damper pads but you can use a piece of cardboard wrapped in duct tape. Fold it so it is thick enough to wedge into the area that is vibrating to get rid of the noise. good luck
Aug 18, 2010 | Refrigerators
Fridge overheating but ice forming on back inside of fridge but water forming at front
My fridge has a very hot front frame which can be felt when the doors are open. Ice is forming on one of the drawers making it hard to open.Its a whirlpool Model Number 6G25DCXHSOO.
My location is Raby in sydney NSW.
Aug 07, 2010 | Refrigerators
Godrej Pentacool Model No GF21 is not cooling properly, please solve this proublem.
Feb 13, 2010 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
