Question about Panasonic Televison & Video
What is the proxy setting for tcp55st30
How do I find the proxy setting for a tcp5530
Panasonic TV model number TCP55ST30. blinks 7 times disconnected ribbon from A board & connector from the Pmain board to the SC board it on & now 8 blinks. reattached Pmain to SC board now 6 blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 05, 2016 | Panasonic 55 TCP55ST30 551 3D HDTV Plasma...
Tip
All GPRS manual settings (All network)Exlusive
AIRTEL MANUAL GPRS SETTINGS
AIRTEL LIVE
Proxy and Server Adress - 100.1.200.99
Accespoint Name - airtelfun.com
MOBILE OFFICE
Proxy - disabled/no
Accespoint Name - airtelgprs.com
Idea Manual Gprs Settings
IDEA GPRS
Proxy and Server Port - 8080
Proxy and Server adress - 10.4.42.45
Databearer - GPRS / Packetdata
Acces Point Name - imis
idea internet:
Proxy - disabled/no
Accespoint Name -internet
Vodafone Gprs Settings
VODAFONE GPRS
Proxy Address: 10.10.1.100
Proxy Port: 9401 or 9201
Data Bearer: Packet Data
Packet Data Access Point: portalnmms
vodafone internet
Proxy - disabled/no
Accespoint Name -www
TATA DOCOMO MANUAL GPRS SETTINGS
TATA DOCOMO DIVE IN
Proxy and Server adress - 10.124.94.7
Acces Point Name - tata.docomo.dive.in
DOCOMO INTERNet
Proxy - Disabled / No
Acces Point Name - tata.docomo.internet
Reliance GSM GPRS SETTINGS
Reliance GSM WAP Setting
Proxy Server Address : 010.239.221.005or 10.239.221.22
Port : 8080
APN: rcomwap or rcommms
Reliance GSM RCOMNET Setting
ACCOUNT NAME-RCOMNET
APN-rcomnet
BSNL GPRS SETTINGS
1] bsnllive
APN = bsnllive
IP = 10.220.67.131
PORT = 8080
2] bsnlmms
APN = bsnlmms
IP = 10.210.10.11
PORT = 8080
3] bsnlnet
APN = bsnlnet
IP = NONE
PORT = NONE
UNINOR Manual Gprs Settings
Proxy and Server adress -10.58.10.58
Acces Point Name - uninor
Videocon gprs settings
APN : vinternet.com
Videocon WAP
APN : vgprs.com
Proxy server : 10.202.5.145
Proxy port : 8799
on Jan 29, 2011 | Cell Phones
Tip
Gprs & MMs settings for india mobile networks 2
&gt;IDEA GPRS SETTING <span> </span> <span> </span>#Account Name - Idea GPRS <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Homepage - http://wap.ideafresh.com <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Proxy and Server adress - 10.4.42.45 <br /> <span> </span>#Databearer - GPRS / Packetdata <br /> <span> </span>#Acces Point Name - imis <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Authentication Type - Normal<span> </span> <br /> <span> </span>&gt;IDEA MMS SETTING <br /> <br /> <span> </span>#Connection name - IDEA_MMS <br /> <span> </span>#Databearer - GPRS <br /> <span> </span>#APN - mmsc <br /> <span> </span>#User name - <br /> <span> </span>#Prompt password - No <br /> <span> </span>#Password - <br /> <span> </span>#Authentication - http://10.4.42.21:8002 <br /> <span> </span>#Proxy serv. address - 10.4.42.15:8080 <br /> <span> </span>#Proxy and server Port - 8080 <br /> <span> </span>&gt;VODAFONE GPRS SETTING <br /> <span> </span>#Account Name: Vodafone_gprs <br /> <span> </span>#Homepage: http://live.vodafone.in <br /> <span> </span>#User Name: <br /> <span> </span>#Pass: <br /> <span> </span>#Access Point Settings: <br /> <span> </span>#Proxy: Enabled <br /> <span> </span>#Proxy Address: 10.10.1.100 <br /> <span> </span>#Proxy Port: 9401 <br /> <span> </span>#Data Bearer: Packet Data <br /> <span> </span>#Bearer Settings: <br /> <span> </span>#Packet Data Access Point: portalnmms <br /> <span> </span>#Network type: IPV4 <br /> <span> </span>#Authentication: normal <br /> <span> </span>#User Name: <br /> <span> </span>#Password: <br /> <span> </span>&gt;VODAFONE MMS SETTING <br /> <span> </span>#AccountName:- vodafone <br /> <span> </span>#Server:- http://live.vodafone.com <br /> <span> </span>#Proxy:- 196.006.128.012 <br /> <span> </span>#Proxy Port:- 8080 <br /> &gt;BSNL GPRS SETTING <br /> <span> </span>BSNL PORTAL <br /> <span> </span>#Account Name - Bsnl Portal <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Acces Point Name - celloneportal <br /> <span> </span>#Homepage - wap.cellone.in <br /> <span> </span>#Proxy and Server Adress - 192.168.081.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Data Bearer - GPRS / Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <span> </span>BSNL NORTH <br /> <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://petercrys.com <br /> <span> </span>#Proxy and Server address - 192.168.051.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name (postpaid) - www.n.po <br /> <span> </span>#Acces Point Name (prepaid) - www.n.pr <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br /> <span> </span>BSNL SOUTH <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - Your mobile no <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://localhost/home.wml <br /> <span> </span>#Proxy and Server address - **** <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name - bsnlsouth <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br />
on Jan 11, 2011 | Cell Phones
Unable to connect to the proxy server A proxy
This is a brain-dead system default setting from Microsoft. If your company/network requires you to use a proxy server, they can make it happen invisibly to you. There is nothing wrong with turning it off except that your connection might slow down if there is a proxy on your network and you don\'t use it. Proxy can cache (save recent pages) and/or restrict your access (filter porn sites). Filtering should be invisible or not configurable by users. The MS default is just plain wrong.
Oct 11, 2013 | Google Chrome
In webfreer I cant connect through the net, the error is: A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a...
solution is very easy..open webfreer..open settings..on the left side click extensions..update extensions..and enable secure https proxy
Aug 03, 2013 | Google Chrome
Hola someone tell me how to change up into proxy server help.
What is your default browser? Settings for using a Proxy server differs from each browser. For example, The settings for Mozilla Firefox browser are as follows,
  1. Click Tools->Options;
  2. "General", "Connection Settings";
  3. Select "Manual Proxy Configuration";
  4. Enter proxy IP and port to appropriate fields;
  5. Click OK to close Connection Settings;
  6. Click OK to close Options;
  7. Reload browser.
You must also be aware that the use of proxy servers without the express permission from the owner of the proxy server may be illegal in some states and/or countries. Use at your own risk.
Using a Proxy server masks your real IP address with a masked IP address. You can ensure this by visiting www.IP-Details.Com and check your IP before and after using a Proxy server.
Nov 12, 2012 | Computers & Internet
Proxy setting 130
Exactly error: "Unable to connect to the proxy server
A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a proxy, but Google Chrome can't connect to it.
Here are some suggestions:
If you use a proxy server, check your proxy settings or check with your network administrator to make sure the proxy server is working.
If you don't believe you should be using a proxy server, try the following steps: Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed."
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Sep 19, 2011 | Google Chrome
Please help me for gprs settings manually
Manual Idea Gprs Settings
  1. Account Name - idea_GPRS
  2. Username - Blank
  3. Password - Blank
  4. Homepage - http://wap.ideafresh.com
  5. Proxy and Server Port - 8080
  6. Proxy and Server adress - 10.4.42.45
  7. Databearer - GPRS / Packetdata
  8. Acces Point Name - imis
  9. Proxy - Enabled/yes
  10. Authentication Type - Norma
l
Manual Bsnl Gprs Settings
  1. Account Name - BPL WAP
  2. Username - <Blank>
  3. Password - <Blank>
  4. Proxy - Enabled/yes
  5. Homepage - http://techarena.in
  6. Proxy and Server address - 10.0.0.10
  7. Proxy and Server Port - 8080
  8. Acces Point Name - mizone
  9. Data bearer - GPRS/ Packetdata
  10. Authentication Type - Normal
Manual Airtel Gprs Settings
  • Homepage - any page you want to set. (eg. http://techarena.in)
  • User Name - Blank
  • Password - Blank
  • Proxy - Enabled/yes.
  • Proxy and Server Adress - 202.56.231.117
  • Proxy and Server Port - 8080
  • Data bearer - GPRS or Packet Data.
  • Access Point Name - airtelgprs.com
  • Authentication Type - Normal
  • Use preferred access point - No
Manual Airtel live settings
  • Account Name - Airtel_live
  • Homepage - http://live.airtelworld.com
  • Username - Blank
  • Password - Blank
  • Proxy and Server Adress - 100.1.200.99
  • Accespoint Name - airtelfun.com
  • Data bearer - GPRS/ Packet Data
Mar 29, 2011 | Cell Phones
Whose nokia 2690 net connect
Take any multimedia and set
Hutch GPRS Settings
* 1. Account Name - Hutch_GPRS
* 2. User Name - Blank
* 3. Password - Blank
* 4. Proxy - Enabled/yes
* 5. Access Point Name - portalnmms
* 6. Full Internet Access Point Name - www
* 7. Proxy and Server address - 10.10.1.100
* 8. Proxy and Server Port - 8080
* 9. Homepage - http://hutchworld.co.in
* 10. Authentication Type - Normal
Airtel GPRS Settings
* 1. Homepage - any page you want to set.
* 4. Proxy - Enabled/yes.
* 5. Proxy and Server Adress - 202.56.231.117
* 6. Proxy and Server Port - 8080
* 7. Data bearer - GPRS or Packet Data.
* 8. Access Point Name - airtelgprs.com
* 9. Authentication Type - Normal
* 10. Use preferred access point - No
* 1. Account Name - Airtel_live
* 2. Homepage - http://live.airtelworld.com
* 3. Username - Blank
* 4. Password - Blank
* 5. Proxy - Enabled/yes
* 6. Proxy and Server Adress - 100.1.200.99
* 7. Accespoint Name - airtelfun.com
* 9. Data bearer - GPRS/ Packet Data
Idea GPRS Settings
* 1. Account Name - idea_GPRS
* 2. Username - Blank
* 4. Homepage - http://wap.ideafresh.com
* 5. Proxy and Server Port - 8080
* 6. Proxy and Server adress - 10.4.42.45
* 7. Databearer - GPRS / Packetdata
* 8. Acces Point Name - imis
* 9. Proxy - Enabled/yes
BSNL GPRS Settings
* 1. Account Name - BSNL WAP
* 2. Username -
* 3. Password -
* 5. Homepage - http://wap.mizone.bplmobile.com
* 6. Proxy and Server address - 10.0.0.10
* 7. Proxy and Server Port - 8080
* 8. Acces Point Name - mizone
* 9. Data bearer - GPRS/ Packetdata
Mar 03, 2011 | Nokia 2690 Cell Phone
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
