Question about Dell Computers & Internet
Start the PC with bootmgr - Dell Computers & Internet
    Scholar:
  • 175 Answers
If using vista, windows 7 or 8 you don't need to anything with bootmgr. this is part of windows booting up.
Posted on Feb 02, 2015
What happen when pc says bootmgr is compressed?
if you have the OS disk you can use that and fix windows bootmgr.
Mar 09, 2015 | Microsoft Computers & Internet
Bootmgr missing
You need to have a operating system's disc because you would need to load the bootmgr from it. Insert the disc and start your computer. Your computer will ask you to boot to the cd. Hit enter and run a start up repair so that the missing system file will be added.
I hope this helps!
David
Jun 22, 2013 | Dell Vostro 1014 Notebook
Bootmgr is missing on another computer how to fix
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
This has happened to me a few times. Just go to that link and it will solve your problem. :)
Apr 17, 2013 | Compaq Computers & Internet
What does BOOTMGR MISSING mean when you turn on your pc?
Boot manager. Try this
Google this: cyberst0rm blogspot how to fix bootmgr is missing
and that has 2 options to repair your problem. Very common.
Sep 05, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
When pc boots it says bootmgr is compressed and does not boot
Boot using the Vista DVD or the respective OS Disc and use the "Repair Option" or go the next step.
Boot using the Vista DVD or the respective OS disc. Go to the Command Prompt. then type the following.
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h.
This should Work.
Oct 25, 2010 | Computers & Internet
BOOTMGR is missing. Acer 4730Z
You need to Have Operating System (Windows disk). Boot your computer with the help of disk and run repair take the option of Start up repair. Run repair and it will fix your Bootmgr missing error and you will be able to log on to windows again.
Jun 01, 2010 | Acer Aspire 4730-4516 Notebook
Missing bootmgr
sir try copy the bootmgr to other computer.
Feb 09, 2010 | Acer Aspire One PC Notebook
Bootmgr image is corrupt error message at startup
1) start up on safe mode ... try to do a restore ... all programs - accessories - system tools - system restore
2) reload windows
Oct 05, 2009 | Compaq CQ60-215DX Notebook
Hard drive compressed/bootmgr compressed
I'm assuming that you are running vista. Try one of the following:
You will require a Vista DVD to boot off of.
Proceed to the System Repair Option, and follow the steps. It should repair your boot sectors..
Or
Once you have booted up, Press SHIFT+F10 to run 'cmd' prompt.
Then at the command prompt type the following (hitting <enter>) after each line.:
del bootmgr
ren temp bootmgr
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
