Question about Toshiba MK2552GSX 250 GB SATA Hard Drive
Toshiba mk2552gsx jumper setting - Toshiba MK2552GSX 250 GB SATA Hard Drive
Jumper settings
http://storage.toshiba.com/storage-services-support/technical-support/jumper-settings-for-pata-drives
Aug 13, 2013 | Toshiba MK5076GSX 500GB 5400 RPM 8MB Cache...
I have a toshiba portege m100 with a bios password set that i need to bypass. toshiba want 80 quid just to look at it. some sorces say short clr1 jumper but i cant find it on my machine. please help.
Most DESKTOP computers have a jumper to "clear CMOS settings",
but most NOTEBOOK computers do NOT have that jumper.
The password exists to protect the owner of the computer, should a thief be trying to use the computer.
You probably can remove the disk-drive, and copy the files onto a new computer, if you don't want to pay TOSHIBA to bypass the password.
Feb 26, 2011 | Toshiba Portege M100 Notebook
FORGOT MY BIOS PASSWORD JUST WANNA RESTART TO FACTORY DATE PLZZZZZZZZZZZZZZZZ HELP ME OUT. JUST WANT TO SET IT TO OUT THE BOX SETTING
FOR TOSHIBA BIOS PASSWORD
It's very Easy.. remove ram cover then remove ram try to find a very small jumper near the ram bank .if u didn't get remove the sticker which is under the ram bank u will see a very small jumper .short the jumper for 15 second with flat screw driver.. if same ..do again but keep short jumper and turn on laptop for 15 second .... if this solution not help full.. then remove the battery cell and wait for 15min. Thanks
Dec 06, 2010 | Toshiba Satellite L505ES5018 Laptop
I HAVE A TOSHIBA MODEL:L505-S5990 I HAVE A PASSWORD BIOS HELP TO UNLOCK MY LAPTOP THANKS ADVANCE SAY ME WHAT CAN I DO
locate the jumpers for reseting the BIOS with hardware... beware all settings on CMOS would be restored to default factory settings and password will be erased. Jumpers would be on the mobo near the proc/ near the memory modules/ near the edge etc...learn to use the jumpers from manuals for ur model of laptop...cos each model varies in the location and use of jumpers
Sep 05, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Maxell pen it is a Toshiba MK2552GSX ATA
I change the FAT formular to FAT32 stick now works
Feb 01, 2010 | Computers & Internet
I/O Magic drive is really Toshiba SH-S182 - I need jumper help
The jumper settings are located in the manual. You can download it here (it takes a few minutes to download). I have tested it and it does work and has the jumper settings for you.
I would be most grateful if you would rate my answer for me. Thank you.
Aug 01, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
How to set a Toshiba MK8064GSX hard drive as a slave? The web site shows a group of 4 pins (2 over 2) This drive has 4 pins in a row.
u have to set the jumper to the set of 2 pins that are after the power cable socket
suppose this is the powercable socket 0000 then the jumper will be set to the 2nd row of the folling pins assembly that will be 0000 :[:]:: jumper position -> [ ] look in to the pic and u need to set the jumper on the pins that says slave
Jul 08, 2009 | Toshiba MK8034GSX 80 GB SATA Hard Drive
HP dv5 heating up
if hp dont have solution for that my advice is buy a laptop cooler or call HP to replace your computer, i was looking for the reviews and there are no negative reviews and hardware heating
Mar 20, 2009 | HP Pavilion dv5-1140us Notebook PC
Jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Oct 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba MK2552GSX 250 GB SATA Hard Drive Logo
161 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
