Question about Toshiba Satellite S955
How do i remove bios password on my laptop?
My toshiba laptop has a 15-6 inches screen and i want to how i can remove bios password on it.wen i start it the bios password appears and i want a way to remove it
    Top Expert:
  • Toshiba Master
  • 1,144 Answers
sandrew
  • 2961 Answers
SOURCE: removal of bios level password
Some laptops are passworded default at'oooo' or 'ooooo'. The bios re-set is the 'JBAT1' terminal, from jumpers 1-2 to 2-3 for a few seconds and then back to 1-2 again, but where the terminal is exactly on your motherboard i do not know. You may also try removing the bios didc shaped battery for 15 minutes or so, then replacing.
Posted on Jan 07, 2007
Maanita
  • 1142 Answers
SOURCE: BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
Posted on May 03, 2008
  • 10406 Answers
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Posted on May 27, 2009
ginko
  • 19396 Answers
SOURCE: toshiba a120 bios password
It cannot be removed using software.
To remove the password you will have to remove the CMOS battery located on the lower side of the motherboard.
To access the battery the computer must be disassembled completely.
toshiba satellite pro A120 opening guide - Digital World
Laptop Disassembly Help
Posted on Sep 05, 2009
  • 66 Answers
SOURCE: I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Posted on Nov 04, 2009
Forgot password and asking to input password for toshiba MK1665GSX.
Desktop or Laptop computer ????
Which operating system ????
The password, otherwise known as the BIOS password that has been made into part of the Toshiba Satellite Laptop design, was built in for security reasons.
However, Toshiba has also made life a little more difficult for those who have accidentally set the password, have forgotten it and don't know how to reset it.
To prevent these troubles, there are routes to resetting or deleting the password completely from Toshiba laptops, including the Toshiba Satellite.
Making the BIOS Password Removal Tool
There is a connector plug that can help you with removing the BIOS password from your Toshiba Satellite laptop, including model numbers 1415, 1800 and Pro 6100. In fact, they work on most Pentium III Toshiba and Pentium IV Toshiba laptops.
To make this tool, take the DB25 connector off of your printer.
Remove the screws to take apart the plug.
When you take it apart, you will see a bunch of wires there which should have enough length to strip and solder them.
The pins on the connector are marked between 1 and 25, so connect the wires together from the following numbered pins: 1+5+10, 2+11, 3+17, 4+12, 6+16, 7+13, 8+14 and 9+15.
Some of these may already be connected inside of the plug.
Insulate these groups of wires with electrical tape.
Using the BIOS Password Removal Tool
Connect this plug to a parallel port in your laptop and turn the power on.
This will take you past the password setting stage and right into the operating system.
If you are not comfortable with making this tool yourself, you can purchase it online.
It will save you some time and effort.
Check the list of laptops with which it works to make sure that yours is one of them.
Other Methods
There are two other methods that you can use to remove the password from the computer.
One is the option to buy the guide online, but you don't find out what the instructions are until you have paid for the product.
If you are not comfortable with this option, then you can try the following option.
When you start the computer you will see the KeyDisk, which is the 'A:' prompt.
When you see this prompt, type in 'SBFIXMBR'.
This will take you through a number of instructions.
Follow these and it will take you past the BIOS area and into your operation system.
You can also call Stratum or visit the Toshiba website and download the Toshiba BIOS Update.
This update can be used to flash the BIOS, although in some cases, you will have to reinstall your operation system and will not be permitted access to BIOS at all.
How to remove BIOS password from Toshiba laptops
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
Oct 28, 2013 | Toshiba MK1665GSX 160GB 5.4K RPM 2.5 Inch...
Tip
Remove Toshiba BIOS Password
TOSHIBA BIOS PASSWORD DONGLE
Some earlier Toshiba laptops BIOS password can be removed with a printer port dongle.
You can build a dongle that plugs into the printer port.
Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg
this is a picture of the finished dongle
Solder wires to the following pins.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
on Mar 16, 2010 | Computers & Internet
My computer says wen i turn it on enter built-in HDD1 password it is a toshiba A200 laptop anyone that can help email me please thanks craighowarth58@yahoo.co.uk cheers people
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
Sep 18, 2010 | Toshiba Satellite Pro 6000 and 6100 14.1...
Don't know BIOS password
Here's how to reset password
Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptops can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jul 25, 2010 | Toshiba Satellite A105 Notebook
Black screen with a enter pass word
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password..
OR there are other places that will sell you a "Key" for a price.
OR you can provide "Proof of Ownership" to Toshiba, and they will sell you a "Code" to remove the Anti-Tamper, Anti-theft, protection.
Apr 07, 2010 | Toshiba Satellite A135-S2276 Notebook
Need to shut off bios password on my L300
Removing the BIOS battery will not reset the BIOS and remove the BIOS password.
On earilier model Toshiba a parallel port dongle will remove thw BIOS password.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Mar 29, 2010 | Toshiba Satellite Pro L300 Notebook
How to remove the cmos or bios password and want to remove the password in booting up, my laptop is toshiba satellite a135-s4527
Mar 18, 2010 | Toshiba Satellite A135-S4527 Notebook
I can't clear the bios password on Toshiba Te 2100. Have removed the RTC Battery. Pse Help
Toshiba BIOS passwords cannot be removed by taking out the BIOS battery. You need to construct a piece of hardware.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Feb 26, 2010 | Toshiba TE2100 Notebook
Cant get pass bio screen on satellite m105-s3084 toshiba
The Toshiba BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work. There is a hardware hack solution (a dongle) to remove the password.
Buy a 25 pin male D Sub connector and join the following pins together by soldering wires to these pins. Make sure the wires do not short against each other. The pins are numbered on the connector.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle into the printer port of your laptop and power up the laptop. Press F2 function key to get into the BIOS and then remove the password. Your laptop should boot up without the password and you can remove the dongle.
Feb 10, 2009 | Toshiba Satellite M105-S3084 Notebook
Removal of bios level password
Jan 06, 2007 | Toshiba Satellite M105-S3001 Notebook
Toshiba Satellite S955 Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
