Question about ASUS Computers & Internet
The outgoing voice on my yahoo messenger dont work
    Habit-Forming:
  • 143 Answers
Check voice recognition device/ your mic.
Set it as your output device.
Updatea messenger,.
Posted on May 23, 2015
3 Suggested Answers
EMKartha
  • 163 Answers
SOURCE: Yahoo Messenger Problem
Which version of Yahoo Msgr you are using. Is it version 10. Ofcourse it should have a video call facility and this requires a good bandwidth, recomended Broadband connection. If you have any problem with the bandwidth the msgr would hang. Else it could be an issue of a spyware, malware of any virus program running. A virus program can capabily run another service thread in the kernal when you start your yahoo features thus making the system go hung or the application itself. Check for such programs using a good Antivirus.
Posted on Feb 13, 2010
tonys_tiger
  • 791 Answers
SOURCE: i dont have video & voice chat on my yahoo messenger
change in setting/setup
Posted on Apr 05, 2012
Yahoo voice call not working
Make sure ur mic settings are configured properly.
Open Yahoo Messenger Window, goto Actions > Call Setup as seen below:
Now follow the step by step instructions, and select the input and output source from the drop down menu on the setup screen until the microphone and speakers are working properly with this wizard.
Yahoo Audio Prefernces
Go to yahoo messenger main window , Messenger > Preferences > Calling & Audio
In this setup, select the microphone input from the dropdown, and similarly the speaker settings.
After selecting the proper input and output, the voice char worked just fine with me. Hope it helps you solve your problem.
Aug 26, 2010 | Yahoo Messenger
Voice chat not working
It's clear that you are not using the correct version of Yahoo messenger, some version like Indian version doesn't support voice chat, but US version do. You can download the US version from this link http://messenger.yahoo.com/download/win/ But firstly you need to uninstall the installed version so that it'll not overwrite or retain the old version. Good luck.
May 17, 2010 | Yahoo Messenger
I can't call pc to pc
It may have some causes:- First, check your internet connection. You should run the Call Setup Assistant before making voice calls for the first time. To run the Call Setup Assistant: Open the "Messenger" menu in the main Yahoo! Messenger window, and click "Preferences." Then, in the Preferences dialog box, click "Calling and Audio." In the Calling and Audio dialog box, click "Open the Call Setup Assistant." Follow the instructions to test your microphone and speakers and specify your Internet connection. Running the Call Setup Assistant will ensure that you have a high-quality voice experience within Yahoo! Messenger. You can run the Call Setup Assistant at any time to make sure your microphone and speakers are working properly or to change the type of Internet connection you are using. One important thing, your firewall must support outbound TCP (transmission control protocol) connections for the PC-to-PC voice feature to work. You might have a firewall blocking Yahoo! Messenger's PC-to-PC voice feature. If so, you need to open up some outgoing TCP connections. Note that it is the outgoing connections that matter, not incoming connections. In most firewalls, you have to specify a destination port or port range to open. Learn more about which ports Yahoo! Messenger uses. Even if you don't use a firewall, your Internet service provider (ISP) may use a firewall, a network address translator (NAT), or a proxy server that blocks voice traffic. Any of these could prevent you from using the PC-to-PC voice feature in Yahoo! Messenger. Please contact your ISP's network administrator for assistance getting around these issues. You must know that what ports are used by Yahoo! Voice services. Yahoo! Messenger with Voice will work if any one of these TCP ports are open: 5061, 443, 80. At least one of these ports must be open in order to make PC-to-PC or PC-to-phone (Phone Out) calls, or to receive calls (Phone In). If your connection to the web is through an http proxy, then you won't be able to make or receive calls with your PC. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
I cannot connect in messenger voice service
remove ur old messenger and download new messenger and chek ur sound ok.thank u
Jun 03, 2009 | Yahoo Messenger
I'm using yahoo messenger version 9 the call doesnt work
make sure yahoo messenger is in you "allow" list for your firewall
From the Control Panel, click Security Center. >From the Security Center, click Windows Firewall. >in the Exceptions tab, click Add Program.> In the Add a Program dialog box find yahoo messenger and check the box next to it =]
May 29, 2009 | Yahoo Messenger
No incoming and outgoing call
You may be behind a firewall or NAT. You can set an option that you are; if that still does not work, you may need to open some ports on the firewall.
Yahoo! Messenger uses a variety of ports.
Service Ports Chat & Messenger TCP Port 5050: Client Access only Insider/Room Lists TCP Port 80: Client Access only File Transfer TCP Port 80: Server Access.
Your ISP may block this port, as its used for web hosting.
You can change port in Messenger, Preferences, File Transfer. Voice Chat UDP 5000-5010
TCP 5000-5001: Client Access
If UDP Fails, TCP will be used instead, see below. WebCam TCP Port 5100: Client Access Super Webcam TCP Port 5100: Server Access P2P Instant Messages TCP Port 5101: Server Access
PMs between Buddys may not use the Yahoo! Server, but this is not a requirement.
Feb 03, 2009 | Yahoo Messenger
Yahoo messanger voice service is not working
Dont use yahoo messenger for ACER ASPIRE ONE not compatible, I suggest use SKYPE messenger text chat, video and voice call as well work great.
Yahoo messenger work only video and text chat only but voice call not work.
Skype messenger works video and voice call works perfectly.
Nov 23, 2008 | Yahoo Messenger
Yahoo voice chat
I have old yahoo messenger 6
but couldn't connect voice in chat rooms
Can you help me please?
Aug 21, 2008 | Microsoft Windows Vista Ultimate Edition
Yahoo messenger 'call computer' not working
Hey.. Just got solution for this, all you need to do is go to Preferences (Ctrl+Shift+P) and then go to Connection and down below you would find Internet Connection, set it to HIGH-SPEED (T1-LAN) and click on Apply and then Ok. All you have to do now is to EXIT (dont just close it but Exit out of the Messenger) and then launch the Messenger again. You should have the Call setup options under Calling and Devices in Preferences. (Preferences are under the Messenger menu) -- Dev
Aug 17, 2008 | Logitech 250 Headset
Computers & Internet Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
