Question about Fujitsu LifeBook P1610 Tablet PC
How do i use the sim card in my hp 2710p - Fujitsu LifeBook P1610 Tablet PC
I want software and drivers for 2710p for windows 7
Hi John this link should help
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3355644
Jun 06, 2012 | Compaq 2710p Tablet PC - Intel Centrino...
Hp 2710p ram cannot go 3Gig
Hi Are you running win 7 32 bits?enterprise?
Jan 28, 2012 | Compaq 2710p Tablet PC
My HP compac 2710p is working O.K. when attached to the electricity. it shuts down completely when i pull off the plug. this is new. thanks, judith
Hey Judith, I have had a similar problem with my wife's Dell laptop. Unfortunately, the only solution was to replace the battery. Laptop batteries do not last forever. Did you notice that it was staying charged less? If so, that is the case. You can pick up a battery at Amazon.com. Here is a link to what you are looking for. Hope that helps!
Sep 01, 2011 | Compaq 2710p Tablet PC - Intel Centrino...
Cant find drivers for HP Compaq 2710p touchscreen.
Hi hbeach1998,
To download drivers for your Compaq 2710p:
  1. Visit www.hp.com/support.
  2. Click "Drivers and Software."
  3. Enter "compaq 2710p" in the "Enter a product name/number" field and click "Search."
  4. Select your computer's operating system from the list.
  5. Click the "Download" button next to the driver you need (they're sorted by device type) and follow the on-screen instructions.
I hope this helps!
May 26, 2011 | Compaq 2710p Tablet PC - Intel Centrino...
I need reset bios password Notebook HP Compaq 2710p
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: reset BIOS Password?
So I would suggest you the 1st method. Hope it helps.
Aug 30, 2010 | Compaq 2710p Tablet PC
Hp 2710p touchscreen and or stylus not working
Probably the connector between screen and mobo has come loose, it a common problem, I had the problem on a Tx1000, remove the battery, and underneath is a small casing, remove that and there should be several connectors, check and see if they are all inserted
Jul 12, 2010 | Compaq 2710p Tablet PC - Intel Centrino...
HP 2710P will not power on!
Try power draining your computer first. remove battery and ac adapter, then press and hold power button for 15-20 sec. Expect no response since there is no power source. After that, try if pc will now turn on. If it still wont, possibly it will be needing a motherboard replacement.
Apr 26, 2010 | Compaq 2710p Tablet PC - Intel Centrino...
Hey folks, first time poster here. I have a HP Compaq 2710p Tablet PC. The error is "Non-System disk or disk error. Replace and stike key when ready" Is this drive toast or can the data be recovered? If...
Normally this means the cpu is trying to boot from your cd drive and it is a non system disk in the drive. When you boot your cpu open the drive and make sure it is empty. If so if you have any other disks or mem cards in the cpu then remove them and your cpu should start up. If this is not the case, let me know and I will help you further.
Nov 10, 2009 | Compaq 2710p Tablet PC
How to remove cmos battey to rest bios in hp 2710p laptop
Go on your manufacturer's website, find the maintenance manual, find where is located the battery and just remove it for a few seconds it may remove the password on your bios. Good Luck!
Mar 23, 2009 | Compaq 2710p Tablet PC
My HP Compaq 2710p will not charge
I PUT A HEAT SINK FROM A CPU AND ATTACHED COOLING FAN TO THE HEAT SINK
AND THAN ATTACH IT TO THE BLACK OBLONG LONG RECTANGLE BOX LIKE OBJECT AND IT WILL STAY VERY COOL AND ALSO SAVE THE BATTARY FROM OVER HEATING AND DAMAGING THE BATTERY.
RODGANDYSR
Mar 07, 2009 | Compaq 2710p Tablet PC
Fujitsu LifeBook P1610 Tablet PC Logo
Top Fujitsu Tablets & eReaders Experts
k24674
Michael Vincent Cruz
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
