How can i fix E2 error in split AC ?
E2 is shown on kenstar 1.5 ton AC, there's no cooling.
  • 234 Answers
SOURCE: AC is not cooling
I would say you have a freon leak. May be the outside unit is not running now because the low psi switch has it off because it does not have enought freon.
Posted on Apr 07, 2009
  • 51 Answers
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
Posted on Apr 13, 2010
hvac1960
  • 2133 Answers
SOURCE: samsung split ac 1.50 ton
E-2 means coil sensor defective. Replace it.
Posted on Dec 07, 2010
SOURCE: Whirlpool Mastermind chrome 1 ton split ac, newly
how to use blower
Posted on Jan 11, 2011
ZJLimited
  • 17970 Answers
SOURCE: E2 error code in samsung
From all Samsung recomendations... if your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864) any day between 9:00 a.m. and 9:00 p.m. Have the model number and serial number of your air conditioner on hand when you call.
Hope helps.
Posted on Jun 29, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
I have 1 ton ac when switch on shows 88 and then switch off
There is 100s of 1 ton air conditioners out there, please be more specific!
Aug 13, 2017 | Heating & Cooling
Dometic b3200. What does error code e2 indicate?
thermostat not seeing 2nd ac unit if switch to select microwave or ac ?
Dec 06, 2015 | Dometic Rooftop RV Air Conditioner
What is the measurement of ton on ac units.
Ton is a measure of cooling only when buildings were cooled by ice and how many tons of ice they would use in 24 hours.
British Thermal Units (BTU's) is also a measure of cooling as well as heating in 1 hour.
1 ton equals 12,000 BTU/hr and 1 watt equals to 3.41214 BTU/hr.
Jun 15, 2015 | Heating & Cooling
Is it worth investing on Panasonic cube AC now? OR should I wait till performance feedbacks are available?
Dear All, After looking at the ads and influenced by the Reliance Digital Marketing Team unfortunately I bought 1.25 Ton Pansonic Cube AC for my House. The Model is disastrous and I am not even getting minimum cooling even though they promised that it will give 1.5 times more cooling than traditional ACs. The Air circulation is also not there even if we sit in front of the AC. When I contacted the service people from Reliance Resq and Panasonic..they are simply saying that the Air will flow straight only..in that case they asked me to fit the AC at 1 Ft height from Floor i.e parallel to my Bed. Which looks much more awkward in the Bed Room. It is better to go for Window AC than fitting this AC at 1 ft height.Air coolers available in the bazaar are better than this product. I feel that I have wasted Rs. 17000/- by investing in it. My suggestion to all of u is Better to buy a USHA Ceiling fan than buying a CUBE model Shashidhar
Feb 01, 2011 | Panasonic Heating & Cooling
How much area can 1hp of this brand can cool
the 'rule of thumb' is 1 ton of AC for every 600 sq feet of a well insulated space (400 sq ft if not well insulated)- for example if the space to be cooled is 1200 sq ft - and is well insulated - you would require a 2 HP unit. 1200 divided by 600 = 2
if the space was not well insulated - you would require a 3 HP unit. 1200 divided by 400 = 3
note; 1 ton of air conditioning - is sometimes referred to as 1 HP or 12000 Btu. Whether you call it 1 HP or 1 Ton or 12000 Btu - they all three mean exactly the same thing.
take this example - 2 tons of air conditioning can also be referred to as 2 HP or 24000 Btu.
fyi - it doesn't matter what 'brand' - they all work off the same principle.
hope this helps
Jun 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
274 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
