Question about Krups VB2158001K BEERTENDER B100
Beertender freezes up - Krups VB2158001K BEERTENDER B100
Krups b100 does not get cold enough. How do i fix this
Maybe the beer inside is cold enough to drink, but the green led that indicates it's ok, doesn't light on. So the thermostat may be not operating well or the ambient temperature is too hot. My beertender B100 is operating without turning compressor off. The compressor never stops operating... even when external temperature is under 26 C... but the beer temperature is ok.
Oct 04, 2013 | Krups VB2158001K BEERTENDER B100
Beertender wont turn on
You may have a problem with the starter on the unit. It will keep the unit from freezing or cooling.
Feb 03, 2013 | Krups BeerTender B95 Beverage Dispenser
Krups beertender not cooling
Replace the capacitors in the power supply circuit 880 and 470 mikrofarada.
Dec 24, 2012 | Krups BeerTender B95 Beverage Dispenser
Can't find beertender adapter tube in stores, need
No clue what that is. Re-post in other sections for a better response.
Dec 09, 2012 | Computers & Internet
I have owned a Krups Beertender for about two years. It has been working fine. The unit thermostat light turned red about 24+ hours ago and mains on. The fan is working. The beer is warmer than usual. ...
It could be the peltier or bad capacitors on the power supply.
http://www.fixya.com/support/t1554764-display_krups_beertender_stopped_working
If it is caps on power supply they are cheap.
Jul 21, 2012 | Krups BeerTender B95 Beverage Dispenser
My beertender stopped cooling my keg. what can I do to fix it?
Wondering if you found a solution to this yet. Mine stopped cooling, too.
Oct 03, 2010 | Krups BeerTender B95 Beverage Dispenser
WHERE CAN I PURCHASE A PELTIER FOR THE BEERTENDER?
I found mine on Ebay. for the price I bought two of them since they will fail. The part number is:
TEC1-12705 Thermoelectric Cooler Peltier 50W 77Wmax
Sep 20, 2010 | Krups BeerTender B95 Beverage Dispenser
Turned beertender off to change kegs. No it will not turn back on....
The plastic switch on the side is very whimpy. it's either disconnected from the toggle switch on the PCB board. Fiarly simple to verify that. If that is nt it. Your peltier thermalelectric
plate may have gone bad and the beertender may be in a current limit shutdown state. you can verify this by disconnecting the peltier plate from the board. You should do this with the tender not plugged in. mastecutor@gmail.com
cost of plate is only $5 dollars.
Aug 30, 2010 | Krups BeerTender B95 Beverage Dispenser
Beertender freezes
the thermostat is not working right fit a new one,,,,
Aug 08, 2010 | Krups BeerTender B95 Beverage Dispenser
Krups VB2158001K BEERTENDER B100 Logo
21 people viewed this question
Top Krups Refrigerators Experts
Tom Chichester
Terry Hair
JonSnell Electronic
JonSnell Electronic
Are you a Krups Refrigerator Expert? Answer questions, earn points and help others
