Question about Kenmore HE2 Plus Front Load Washer
SD error code on ken more he front load washer
SOURCE: Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Posted on Mar 21, 2008
SOURCE: Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
Posted on Apr 26, 2008
rylee_smith
  • 8619 Answers
SOURCE: Keep getting error code sd or 5d and sometimes a F
Hi
The Sd or 5d indicates that excessive suds are detected by the washer during the drain or spin phases of the cycle. The washer will stop and fill with 4 liters of water and then wait for 5 minutes to allow the suds to dissipate before continuing. If the suds cannot be reduced or eliminated so that the washer cycle can continue, it may stop and display the F21 (long drain) fault code. After the suds dissipate, you can normally drain the washer and spin out the clothes using a RINSE/DRAIN & SPIN cycle. Make sure that you are using HE (High Efficiency) detergent in the appropriate amounts to prevent excessive suds in the washer. This should prevent the washer from going into this routine.
And if you still face the same error then probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Also refer to these diagrams for more details--
Kenmore Drain filter and pump link1
Kenmore Drain filter and pump link2
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 13, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: washer stops and error code sd ( or 5d) shows
Hi, the error code is not 5 D it is "S" as in Sierra d. The letters stand for Slow Drain. I had this code and it was fixed in 5 minutes or less. Simply remove the bottom panel from the front of the washer. In the lower right hand corner, there is a tray to catch any items that may slip past the boot on the door seal. Slide this tray out and clean it. You will be amazed at what is in there...money, bobby pins, socks. Re-assembe the washer and presto.
Take care
Posted on Jun 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Error code sd
SD is a slow drain condition. Remove the bottom front kick plate and clean out the filter. Have a bunch of towels at the ready!
Dec 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Can not clear code sd
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Oct 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
What does SD error code mean on Kenmore HE 2 plus front loading automatic washer
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Long spin cycle of my Samsung WF8590NHM Front Load Washer is always interrupted and throws this flashing "5d" error code.
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
Aug 20, 2011 | Samsung WF306BHW High Efficiency Front...
What does errror code SD mean. My washer also will not drain all the way.
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Apr 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Display says sd
Hi
Daniel
Jan 27, 2011 | Kenmore HE2 Plus Front Load Washer
Sd code: Washer sounds like it is straining during the
This is a suds error. Too much detergent,wrong kind of detergent or a blocked drain pump filter.
Remove the bottom front panel. Unscrew the filter and clean it out. Run a couple cycles with no detergent to clean out the tub. Use only HE soap and the correct amount.
More soap causes problems and does not get the laundry any cleaner.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does F- indicate?
The SD code, is a sudsing code. If you are using the appropriate amount of soap and HE soap, it could be a communication error with the sensor and the CCU (the main control board). If you take off the panel on the bottom of the front (3 screws on the bottom hold it on). Once you get in, there is a plastic pouch on the right hand side there is a tech sheet that will have a list of all the error codes, and what to check.
Good luck
Dec 23, 2008 | Kenmore 43142 Front Load Washer
HE2 front loader error code
According to the HE2 Tech Service manual, it means "Suds Lock (Overdose of detergent detected during the wash cycle).
Aug 29, 2008 | Kenmore 43142 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
11 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
