Question about Maytag Neptune MDG5500AW Gas Dryer
Whirlpool gas dryer heats up and then gets cold
  • 331 Answers
Open the front by removing the door and screws on both sides. look inside to see if the ignitor is turning on. all the time. also it could be the gas solenoid...go here www.techray1.com and hit the guru guy. use the drop down menus to id your part
Posted on Jun 22, 2009
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Gas Dryer Heat wont stay on.
Must be something in the blower section. You need to get into the dryer and clean it up. Air restrictions cause overheat condition. When the temp gets so high the limits shut it down. Lots of videos on you tube that show how to get into. You can google gas dryer dan webster or roper dryer no heat dan webster and I have some videos posted how to get into these.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Will not get hot. just blows cold air. was wondering how many heating eliments are in the dryer?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 30, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
I have a Whirlpool gas dryer, LGR5636JQ0. It will
if the vent is clogged or duct in back of machine is will over heat and safety will shut off heat pull maching out check ducts and exhaust prt on machine
Jul 06, 2009 | Whirlpool LGR5636L Gas Dryer
Initial heat then goes cold
Very common change the gas valve coils and you are good to go easy repair i can ship them to you free and tell you how to do it in no time... call me whirlpoolpartssurplus.com
Jun 26, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Jun 15, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer tripping breaker when plugged in.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
Oct 16, 2008 | Whirlpool LGR8648 Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
273 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
