Question about Stens Primer Bulb Tecumseh 632047 St120-200
How to replace this primer bulb on craftsman 20" lawnmower
Lawnmower model number: 917.380590 Primer bulb # 632047
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
Where is the primer bulb o my toro lawnmower
Typically a primer is only used on 2 cycle engines not on lawnmower engines, so it would not have a primer bulb.
Jul 15, 2014 | Toro Garden
Where is the primer bulb on a craftsman gold 6.0 walk behind lawnmower
The primer bulb should be near the air cleaner. There may be a black cover right above it.
Aug 19, 2013 | Briggs & Stratton Garden
Can I replace just the primer bulb
yes useing a thin small screwdriver slide it down the side and work the spring slowly out revers this to put a new one in
Feb 14, 2013 | Mtd Craftsman 4Cycle Mini Tiller
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Where can i download craftsman lawnmower manual 917.377563
If you go to sears parts and put in your model number it will show a drawing with all the parts you need.
Jan 28, 2012 | Sears LiftMaster Garden
Missing T piece from primer bulb to carburator
Sears has replacement parts and so do the OSH stores. If there's no store close, check with a local lawnmower shop and I'm sure they've got lots of replacement parts.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Primer Bulb cracked Need new one?
remove carburetter air filter cover,two 'torx' screws on top.primer bulb is retained in case by 2 plastic 'ears' push ear[s] in& bulb slides out of case.make note/label 2 fuel lines attached; one 'stem' on primer is longer than the other.replacements can be found @ lawnmower/small engine repair shops.
Oct 10, 2009 | Garden
I have a toro lawnmower moel 20695 and whem i
check the gas line between the carb and bulb. Or it could be the plastic primer bulb itself. -a small tear or slice could easily go unnoticed.
Aug 02, 2009 | Toro Lawn Mower With Toro Power Tools
Stens Primer Bulb Tecumseh 632047 St120-200 Logo
48 people viewed this question
Top Stens Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Stens Garden Expert? Answer questions, earn points and help others
