Question about Hobart 84145 Food Processor
How do you adjust the locking hub - Hobart 84145 Food Processor
When the new processor is plugged in, the motor does not work
Denise suspect all items below not locked in to place
have you locked in the work bowl ?
have you locked in the lid ?
have you locked in mouth feed chute ?
For your protection this appliance has an interlock system. The processor will not operate unless the workbowl, cover and wide-mouth feed chute are properly locked in place.
see page 6 and 7 of user manual
http://cdn.spectrumbrands.com/~/media/SmallAppliancesUS/Black%20and%20Decker/Files/FP2500%20Use%20and%20Care%20Manual.ashx
Jan 26, 2016 | Black & Decker FP2500S 10 Cups Food...
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
KitchenAid Food Processor bowl is in wrong position and locked
Thank goodness you have solved it, help was a long time coming. It's a shame these threads don't self lock after a certain period.
Apr 01, 2012 | KitchenAid KFP715 7 Cups Food Processor
I have a kenwood chef mod 703c the motor spins and drives the belt ok butwhen i engage the power switch the mixerhead does nothing, does not turn
The problem is that the clutchdog, which is normally engaged by the peg on the liquidiser cover, is worn. Remove the top casing of the machine by removing the 3 screws and all of the outlet covers. Then unscrew the top of the gear box and prise open carefully with a screwdriver to expose the gears. The clutch dog can be unscrewed. Remove the spring that is on the outside of the gearbox and replace it on the inside of the gearbox so that it pulls the clutch dog down permanently. This then needs to be screwed back once the top of the gearbox has been screwed back together. Sounds complicated but it will be obvious when you try it. The machine will then turn the main attachment hub but will remain engaged as for later model machines. Hope this helps. John UK
Jun 16, 2010 | Kenwood Food Processors
Problems with Braun K3000
1st lock the bowl properly, watch for the arrow pointing in the right direcction. Then lock the lid, properly and watch that it makes kind of a click sound when it enters into de machine. After that you should be able to turn it on
Jan 17, 2009 | Braun K 3000 Multisystem Food Processor
We can`t disasemble it with the dough blade in, any tips?
All of the blades "lock" (rest in a groove) when rotated clockwise. This is so they'll stay put when in operation. When you take the bowl out with a blade in, you're moving the pair in a clockwise direction. So, you lock the blade in, thus locking the bowl down. Either remove the blade first by rotating it counter clockwise, then up or move the blade back 1/10th of a turn after rotating the bowl as far as it will go clockwise.
Jan 02, 2009 | KitchenAid KFP750 Food Processor
Food processor
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Brand NEw DLC-8 not working.
If a part of the work bowl is damaged, it will not properly trigger the motor. Replace the workbowl (original DLC-8 parts not available, but an expensive replacement workbowl is available).
Apr 02, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Hobart 84145 Food Processor Logo
Top Hobart Food Processors Experts
Are you a Hobart Food Processor Expert? Answer questions, earn points and help others
