Question about Surebonder Full Size Low Temperature Glue Gun L-270
Is the L270 glue gun CSA approved - Surebonder Full Size Low Temperature Glue Gun L-270
Tool shop glue gun
that's just an unfortunate side effect of gravity. it happens to all glue guns. as the element heats the glue it turn into a liquid and oozes out of the nozzle. eventually it would stop when once all the glue in contact with the element has oozed out.
check this out.
https://www.youtube.com/watch?v=3H8ZgrOaxRc
Feb 27, 2014 | Tool Shop Dual Temperature Glue Gun 60...
Cold Glue Controller, Model CSA 6
Dear sir
Pls click on the below site or contact them for more info
http://www.gluemachinery.com
Jul 15, 2013 | Crafts & Hobbies
No problem with unit. Is this air conditioner CSA or OSHA approved ?
It's not the unit that you have to worry about for CSA or OSHA. It's how you intend to install it. You have to use the proper installation guidelines as approved by OSHA. I do know that going outside a wall or window you must have the proper bracket/frame installed outside the exterior wall to prevent it from falling on someone's head if high enough. If down low, they still have to be braced/bracketed properly to avoid injury. That's standard procedure.
http://www.osha.gov/SLTC/indoorairquality/
You need to find out what OSHA has for safety guidelines and restrictions. Also check with your local building code office to check with their pre-set guidelines. They have to be automatically in compliance with OSHA if they intend to operate guidelines for business purposes. So Call either- or both. It's not the unit you need to worry about unless it's very old. Good Luck.
Mar 10, 2011 | Maytag M3X05F2D Air Conditioner
I have a glue gun (brand = POWER CRAFT a german product stated) I forced the glue stick into the gun to use up what was left of it and now I cant get it out. Its completly stuck inside the gun. Is the...
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Dec 07, 2010 | Crafts & Hobbies
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Master mechanic glue gun 207 stopped working
There is a glue build up inside. Most likely in the feeding mechanism, try to heat it up, the unplug, and use like a paper rolled up to try to remove some of the glue. :)
Mar 25, 2010 | Crafts & Hobbies
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
Surebonder Full Size Low Temperature Glue Gun L-270 Logo
Top Surebonder Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Surebonder Craft and Hobby Expert? Answer questions, earn points and help others
