Question about Saws
How do i change blades on a mastercraft band saw?
    Sergeant:
  • 468 Answers
Here's an easy step by step instructions on how to change band saw blade. How Do You Change Band Saw Blade
Posted on Aug 01, 2014
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
  • 360 Answers
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Posted on Mar 31, 2009
Editor925
  • 285 Answers
SOURCE: band saw ,blade length
The blade length used on the 9422 is 52.75 inches.
Please rate this solution on FixYa!
Posted on Apr 18, 2009
  • 5 Answers
SOURCE: NEED BAND SAW BLADES FOR MY OLD BLACK & DECKER
sometime you can get lucky on ebay. thats one place you check. the best thing about it that it's nation wide. i found alot of odd items in there.
Posted on Jun 24, 2009
Mastercraft bandsaw blade Model V1132 replacement part?
Fixya does not sell band saw parts.
Sep 09, 2016 | Saws
How do you keep the blade on a 386 band saw from coming off all the tim when puttin on a new one
There are lots of informative blogs on bandsawblog.com . Search for Band saw blade tracking , How to Change band saw blade, Blade tension .
Aug 27, 2014 | Skil 3386-02 9-in Band Saw with
MASTERCRAFT BAND SAW MODEL 055-6748-6
I order my band saw blades on sawblade.com I also use one blade from lennox.
Aug 15, 2014 | Saws
Band saw blade keeps coming off
Set up your band saw properly. There are several reason why band saw blade keeps on coming off on the wheels: loose/wear tire, improper guide adjustment, incorrect tension, over feeding wood stock or the problem could be on the blade itself. Try to change your blade, I got my band saw blades on sawblade.com . I suggest you watch band saw tune up tutorial videos on youtube. Hope that helps.
Aug 13, 2014 | Black & Decker Saws
Need mastercraft 9 inch band saw owners/user manual for 55-6719-6 to be mailed to me, I will pay the expenses
There's some one on wiki answer posted an information about Mastercraft 9 inch bandsaw. Try sending an email to skuhl1959@yahoo.com .
Sep 21, 2013 | Craftsman Saws
Mastercraft 2 in 1 flip over saw only works on one side
You have a safety lock as the table turns to table saw with an open blade.if you don't hear the click or one of the wires on the locking mechanism have come loose it will not function. Used to have one but I wore the motor out - best portable saw I have owned and I own a lot of high end saws.if anyone has a flip saw for sale let me know - pipeline@nucleus.com.
May 31, 2013 | Saws
Blade on my 9 inch mastercraft band saw does not tension properly
Check if the tires are align. The blade must be on the center of the tires. Check for both tires for wear . You may want to
check the blade guides too. They must not touch the blade. I just purchased new tires on www.bandsawparts.com for a
friend. We've learned that his tires are well worn out that's why the blade keeps on coming off on the wheels.
Mar 07, 2013 | Saws
Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Saws Logo
149 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
