Question about Abit AB9 Pro Motherboard
Code 87 turn on and get 87 and shuts off
  • 4 Answers
Check CPU core voltage.
Carl
Posted on Sep 06, 2014
My 2007 gmc envoy shut off while riding down the road I have taken it 2 places and have heard everything from my anti-theft to a seized engine. Help
Is the anti-theft light lit ? If not , not anti-theft problem . Find the crank relay in the under hood fuse / relay box . Pull the relay out of it's socket an look on the bottom of the relay , you will see four sets of numbers > 30 & 87 , 85 & 86 . Where it plugs into the fuse box Jump 30 to 87 , if engine spins it's not seized up . If it shut off how did you take it to 2 places ? Did you take it to the dealer ? Did either place check DTC'S - diagnostic trouble codes ?
Apr 16, 2016 | GMC Cars & Trucks
Rheem pool heater code ifault
check gas pressure if ok then turn up by calibration
Jun 30, 2014 | Pool & Spa
My main relay makes a buzzing sound with the ignition switch in the off position
on a replay there are 2 particular connections that cause that. When you look for numbers on that relay you will find the numbers 30, 85, 86, 87 and 87a. The problem is their is power going to 85 or 86 (they are the 2 control terminals that control the relay). that should not be. basically 87a allows power to go through the relay when the system is shut OFF, Terminal 87 is the path of power that turns on whatever is connected to it. Now... 85 and 86... one of them is ground... the other power. Typically 85 is ground and 86 power. Now to better explain what is going wrong. you have a connection that feeds power to 87a. that power is powering 87 which powers 86. when power is turned on at 87... it turns on 86... that causes the relay to pick up an break the connection of power to 87a while at a fraction of a second later making the contact to 87. So... the path of power is turning the relay on and off all by itself, LOL. I know this is confusing, sorry. But I hope it helps
Mar 19, 2014 | 2002 Kia Sportage
I have a 98 chevy venture...i am not getting any power to the fuel pump and was wondering if there is a safety shut off or if my problem is with the pcm...had to disconnect the negative terminal on the...
If your security light is on, then this is the problem. The security has it's own module, not in the radio. Turn the key on (don't start) let it sit for ten minutes, turn it off for five seconds and then try to start the car. This resets the security. To check the fuel pump. Find the fuel pump relay and pull it out. Put a jumper wire in the relay socket at terminals 87 and 30. 30 is power all times and 87 goes to the pump. If you have power at 30 and jump the relay socket and the pump still wont come on. Then either there is a bad wire (power or ground) or the pump is dead.
Sep 04, 2011 | 2001 Chevrolet Impala
Car starts then shuts down as if no power
In year /model 87, code 23 was oxygen sensor stuck in full rich position. I'd be tempted to try a new one.
May 03, 2009 | 1988 Dodge Daytona
I need to shut off the ringer on my phone
you can turn on DND key or it has to be programmed in programming 81-87
info@ameritelnj.com
Tony
Mar 04, 2009 | Toshiba DKT2010SD Phone
Asks for restriction code for nokia t-mobile 2610b
salut j*ai un nokia 2610 b l*horse que j*allumer il ma demande code de restriction svp envoyer moi ce code ce tel vien de usa et je veux utiliser en maroc merci. type rh-87 ic 661ab-rh87 imei:011673/00/355095/2 code:0565017hp204v
Jan 14, 2009 | Nokia 2610 Cellular Phone
Codes for chorus mmds (EUROVOX)
These are only for boxes that work with Chorus digita MMDS not cable
hit menu
go to system information
hit ok
type 1969
go to navigation
bring up provider
if you are with chorus then
the codes are: PROVIDER ID 5E 01
KEY NUMBER 00
key data: CE 19 23 87 80 61 74 90
KEY NUMBER 01
key data: 62 FA 09 F3 CE 05 F4 79
make sure your provider name at the top is reading CHORUS if not go to the provider id and right arrow until 5E 01 appears and when you have changed the codes store and exit you should be laughing!!!
best of luck HAPPY CHRISTMAS!
chorus
00:CE 19 2E 87 80 61 74 90
01:62 FA D9 F3 CE 05 FA 79
Dec 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes Dec 18th
NTL DUBLIN THURSDAY 18TH DECEMBER 00 Code - B0 B8 4F 04 E6 5F 87 80 01 Code - A3 EB EC 07 D6 49 D2 EB Have fun ****
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
TW Code Starview
New New codes for tw at 17.30 4/12/08
00=co f6 61 87 91 f9 67 57
01=83 35 e5 28 40 49 b2
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
Abit AB9 Pro Motherboard Logo
51 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
