Question about Sunterra 30016 Pond Bio - Filter 1000 Gallons, Black
I have two filter rings, which goes in first. The green finer one or the black coarser one?
What sideof a filter goes nearest to the motor in a cylinder vacuum cleaner, foam or sponge?
Finest filter media. Coarser media towards bag. Possibly fits better in only one position. Check seal around edges of filter when installed.
Jun 01, 2017 | Filter Vacuums
Too coarse a grind
have you tried adjusting anti-clockwise whilst grinder is in operation ?
Nov 11, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My Solis Maestro takes a long time to grind and no longer grinds for espresso. How do you remove the burrs to clean them? Should they be replaces?
HI
Yes the burrs will wear out. They can be replaced. To remove the outer burr. Twist the bean hopper counterclockwise until it stops. Lift the bean hopper out. There is a cream colored ring with 2 tabs that will lift out holding the outer burr. To get the inner cone burr out is a little more difficult. We use a vice grip and grab the burr, and lock the pliers to it. Then with a quick movement clockwise on the pliers, you loosen it. Then clockwise unscrew the burr. When you install the new burr, it truns on counter clockwise until it stops. Insert the new outer burr. Push down so the tabs will lock in. Install the bean hopper into the correct slots ( 1 large tab and 1 small tab). Twist clockwise to turn on and test. Remember it must be grinding to turn to a finer grind but can be turned to a coarser grind any time.
Jan 24, 2011 | Solis Maestro Electric Burr Grinder
My coffee filter for my Keurig, seems to overflow. Making coffee is fine with the pods, but not the filter with which you can use your own coffee... I have tried different types of grinds (ex. fine,...
I have had this same problem when all of some of the coffee is ground too fine. It needs to be the correct particle size and if it is too fine, it will clog the screen and either overflow or not flow at all. Look at the ground coffee you use and check to see if it is uniform size or there are a lot of very fine grounds mixed with the coarser sizing. Try asking a coffee shop to grind you some coffee specifically for your Keurig cassettes. Most pre-grounds drip coffees are too coarse and many grinders in the stores where you grind your own whole beans do not produce a uniform size. I have an OEM Keurig cassettee and two generic cassettes and the screens have different pore sizes, with the Keurig being finer.
Aug 24, 2017 | Keurig Elite B40 Coffee Maker
What is a good grinder setting for miele cva615
IT is somewhere in the middle, but it really depends on your prefferences if you like stronger coffe then finer is better and waeker is coarser, watch if you get to fine the water might not be able to come threw, so i say the middle than adjust ethier way slightlt to taste.
Dec 19, 2009 | Miele CVA615 Espresso Machine
I have a Pixma iP4500 printer.When I buy ink, the #5 black ink tank isn't included in the box. There are 2 black ink tanks in the printer.The #8 black ink tank hasn't been used and the #5 is out(as are the...
There are two black inks in the printer so that when you are printing only black and white such as printing a fax or when you set print in B/W for printed matter, the printer will use the larger ink cartridge. When you are printing in the multicolor mode (most people don't know the difference) the printer will use the finer black ink in the smaller cartridge. This smaller cartridge is used for photo printing and multi-color page printing. You cannot mix the two blacks since the larger cartridge is a coarser ink.
Jun 06, 2009 | Canon Pixma iP4500 InkJet Printer
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Strainer and a Filter differences
Actually there isn’t any since a strainer is, in reality, a coarse filter. The question is then one of semantics. Generally it is assumed that if the particle to be removed is not visible to the naked eye, the unit is filtering, and if the particle is visible, the unit is straining. The average human eye can detect a specific particle between 50 and 70 micros. Most people cannot see anything smaller than 325 mesh, or 44 microns. Since 200 mesh is equivalent to 74 microns, a general rule would be that if the screening device is coarser than 200 mesh, it is a strainer and if it is finer than 200 mesh it is a filter. One of the best uses for a strainer is in conjunction with a filter. By installing a strainer directly ahead of a filter, the large heavy pieces which would quickly clog the filter are removed. The filter is then free to do its major job of fine particle removal and does not have to be cleaned so often.
Aug 27, 2008 | Brasstech Jr. Basket Strainer with washer...
Solis Palazzo Bean Grinding
That one with number on is finer or coarser grinding beans, the other one is for how much gram it would grind. + means more gram.
I hope this will help you.
Apr 28, 2008 | Solis Palazzo Espresso Machine
Sunterra 30016 Pond Bio - Filter 1000 Gallons, Black Logo
48 people viewed this question
Top Sunterra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sunterra Garden Expert? Answer questions, earn points and help others
