Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher glass express ;ight is flashing and there are 2 dashes on the time remaining
SOURCE: whirlpool dishwasher
I can't guarantee to solve this but we had flashingh light problem and in the end all I did was to set the dial to the wash I wanted and kept my finger on the start button for about 10 to 20 seconds and it suddenly woke up and started. It had obviouosy had a hard day and wanted a rest
good luck
Martin
Posted on Jul 02, 2009
  • 67 Answers
SOURCE: Two horizontal dashed line and won't start
A dishwasher operates in a hostile environment. Eventually the corrosive soap can damage the electrics & the electronics. If you have the skills, I suggest you turn off the breakler to the diswasher, then dissassemble the console & control board. Spray the contacts with WD40, & reassemble. The very sliding-action of dissassembly/reassembly should cure any contact issues. I hope that this helps.
Posted on Jul 27, 2009
  • 220 Answers
SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
Posted on Sep 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
rylee_smith
  • 8619 Answers
SOURCE: (cycle lights) flashing "pots&pans", steady
Hi
Thanks for using FixYa. To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 13, 2010
Glass express light is flashing and wont start
SEE THE DIAGRAM, and examine the switch door, if not close the starting relais will not start the main motor.
May 09, 2012 | Whirlpool Dishwashers
Start light flash 2 times on a Whirlpool ADP 6940.
Whirlpool dishwasher start light flashes 7 times repeatedly and wont start
May 24, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
(cycle lights) flashing "pots&pans", steady "normal", 2 steady dash marks on "time remaining" m/n GU2400XTPS3, s/n FS1212944
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Aug 13, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Clean button is flashing
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
I have a Whirlpool model #GU2548XTPQ3 that flashes the glass express cycle when not in use and when using the cycle switches from the cycle that was set to the glass express cycle. The unit will not allow...
I don't know if this will work but it is worth a shot. Try to reset your dishwasher by pushing the buttons in a sequence. Usually it is Heated Dry, then Normal, then Heated Dry again and then Normal again - all in a row, don't pause, but do it in a fast sequence. This will do a diagnostic test and then reset your dishwasher. If that is not the sequence, you can type in your dishwasher name and number and the word reset and usually find it on the internet. I don't use glass express cycle although I see it on my dishwasher too, but I am not familiar with it. I use Normal and Heated Dry and that is all and it works great, so you might try just using those if you get it to reset. Hope this helps!
Jul 28, 2009 | Dishwashers
Jul 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GU2500XTPS3 QUIET PARTNER - NO START.
23310532.jpg The dishwasher will not start. The following things have occurred;
1. The Cycle option light is flashing.
The model is GU2500XTPS3
Can anyone please assist if they have seen this problem before?
Oct 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
138 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
