Question about IBM Correcting Selectric III Electric Typewriter
How do I unlock the keyboard of IBM Selectric III???
Keyboard seems to be locked. the keys won't depress
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
Posted on Mar 02, 2015
  • 186 Answers
SOURCE: IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Posted on Apr 24, 2009
  • 3594 Answers
SOURCE: On the IBM selectric 2 - the keys are locked up -
Try the shift key, then try pressing each key on the key board one may be partially tripped.
DickyO
Posted on May 07, 2009
  • 3594 Answers
SOURCE: My IBM selectric II just stopped typing. None of
You probably have a broken belt, you'll need a tech.
DickyO
Posted on Jun 30, 2009
  • 3594 Answers
SOURCE: IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
  • 3594 Answers
SOURCE: I need to know how to install a ribbon on an IBM
Go to lexmark.com and click your way to publications there you can get instructions and pictures of installation. Remember there are 2 different ribbons for Selectric III,s.
DickyO
Posted on Sep 21, 2009
How do I unlock keyboard?
When you turn off the machine there is a part that locks the keyboard. When you turn on the machine that part is supposed to allow the machine to type but it sounds like it is sticking and will probably need to be flushed and re-lubed. I would only recommend a qualified technician to do this type of repair.
May 08, 2014 | IBM Correcting Selectric Iii Typewriter...
Unlock the security chip for a ibm t 60 thinkpad
IBM-branded Thinkpad T60 laptops from Lenovo are mobile computing devices that feature a keyboard lock for data security. When the lock is enabled, pressing the keys on the keyboard does not result in input to the computer. The lock hampers attempts by an unauthorized user from gaining access to your computer and your files. Lock your Thinkpad using the Function key. The Function key used in conjunction with other keys on the keyboard expand the laptop's number of available features.
Locate the "Fn" key in the lower left corner of your Thinkpad keyboard. Locate the "F2" key in the upper left area of the keyboard. Press and hold the "Fn" key, then press the "F2" key to toggle the "Lock" feature. Release both keys. Hope this helps.
Jan 14, 2013 | IBM Computers & Internet
IBM Keyboard KB9930. Pressing keys types,but shows a different letter to the one depressed.I cannot correct this and have to improperly shut down computer and when restarted, all is well. Have I...
The function key could be damaged or stuck down. If not, try going to Device Manager. Right click on the Keyboard and choose Properties. Click on Update Driver as it might find something. Reboot the computer. If that doesn't work, go to Device Manager, right click on the keyboard, choose Uninstall, and reboot the computer. When it starts up and sees the keyboard and loads a driver(s) for it, it might fix it. Good luck.
Jan 12, 2018 | IBM Computers & Internet
IBM Selectric II was shipped in working order. When I received it, the keyboard locked up. Return works, margins work, tabs work...it just won't type. Can't mash down on the keys or spacebar. Any...
try the shift key, then press every key on the keyboard one may be partially tripped. If all else fails lift the front about 4 inches and drop.
DickyO
Feb 01, 2011 | Office Equipment & Supplies
IBM Selectric Model 71 keys are locked up and won't depress.
First thing try every key one may be partually tripped. Try the shift key that may be out of adj. Most anything eles you will need a tech.
DickyO
Dec 23, 2009 | IBM Office Equipment & Supplies
The keys on my IBM Selectric III typewriter are frozen....is there anything I can do ???
First; depress the tab key. If that unlocks it, then you need a return clutch or torque spring replaced. Does the spacebar or tab key work? Sometimes you can gently press everykey on the keyboard and eventually one will release and unlock.
May 14, 2009 | Office Equipment & Supplies
I can not install windows
Keyboard is locked out - unlock the key
http://www.pcguide.com/ts/x/sys/booterrGBER37-c.html
[[Keyboard is locked out - Unlock the key
This message usually indicates that one or more keys have been pressed
during the keyboard tests. Be sure no objects are resting on the keyboard.]]
http://www.phoenix.com/en/Customer [...] +Codes.htm
Hope this helps. Let us know.
May 07, 2009 | IBM ThinkPad 240X Notebook
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
Selectric III Key Stuck
remove the cover , latch on bottom each side of unit.
turn it on is the belt running or jumped off.
if it is running then the clutch is jammed.
Jan 25, 2008 | Office Equipment & Supplies
IBM Correcting Selectric III Electric Typewriter Logo
1,119 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
