Question about Konica Minolta bizhub C351 All-In-One Laser Printer
How do you turn on the print driver - Konica Minolta bizhub C351 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
You do not turn on the Print Driver. the print driver is on your computer which allows the computer to talk to the printer. when you click print on the computer your C351 should be the printer it goes to. try this site for help
Self Help Product Support Konica Minolta Business Solutions Inc
Posted on Dec 29, 2015
Prints every other line of document
Try reinstalling your printer driver, yours may be corrupted.
Not enough info for a good answer but if a Windows machine, turn the printer off, go to the Device Manager, select Printer, delete the listing for your machine (don't know what you have), Try now turning the printer on.
If your OS recognizes a 'New Device' it will install the printer driver again.
If it doesn't, leave the printer turned on and reboot your system.
One of these should force the operating system to find the printer and install the driver from a backup driver.
Good luck & a tip: Always include details about your printer and operating system when seeking help.
Mar 15, 2015 | Office Equipment & Supplies
HP Officejet 4315 All-in-one I am a Mac user and I cannot do duplex printing or two sided printing
Mac uses a generic driver for all printers. have you verified that duplex printing is check under the printer options?
System Prefs -> Print & Fax -> select the printer, Options and supplies -> driver.
NOTE: if it says print using "Generic postscript driver" you will need to install the manufacturer driver for the printer to get the option to turn on the duplex printing.
May 23, 2011 | HP OfficeJet 4315 All-In-One InkJet...
My HP LaserJet 1022 is not responding even after I click print. It happens just now. Yesterday morning was fine. Keeps the document in pending and when I try to cancel or click print it says the print...
This seems to be a problem on these printers. I have five of them on my network and I had to use a generic driver to make them stop shutting off the print spooler on my print server. I use the LaserJet III driver which is a good HP generic driver. I found it to be best to uninstall all of the 1022 software and install the printer using the above driver that is part of the windows operation system therefore there is no need to download one.
Apr 10, 2010 | HP LaserJet 1022 Printer
HP LaserJet 2100 will not stop printing nonsense when I have cancelled and cleared the print memory. It's going through tons of paper and turning it off, along w/the computer, for several minutes does not...
The "nonsense" is your printer trying to interpret the information. Go to HP.com and download the correct drivers. Delete all other drivers from the Printers and Faxes/File/Server Properties. Then install your correct print driver
Nov 20, 2009 | HP LaserJet 2100 Printer
It keeps on printing test pages
Uninstall the PRINTER'S DRIVER SOFTWARE completely from your system, MAKE SURE YOU USE THE PRINTER'S DRIVER DISK FOR IT OR ANY UNINSTALLER SOFTWARE FOR IT DONT UNINSTALL IT FROM CONTROL PANEL.... DISCONNECT PRINTER, TURN IT OFF. Clear All Temp And Prefetch Files. Restart Your System, Turn On Printer, Hook It Up To Your System,,, Go To The Manufacturer's Website And Install The Latest Driver Software And Firmware If Available....
May 21, 2009 | Kyocera Mita FS 1000+N Laser Printer
"CLOSE BACK COVER", over and over-back cover IS closed.
You have the wrong driver loaded. or your driver has been coppurted. Uninstall and reinstall drivers and software. Check to make sure you have the right drivers first.
Good luck
Mar 16, 2009 | Brother MFC-5440 Printer
EPSON PRINT MONITOR pops up on startup!
Hello I think I might have a way to solve this problem. I had a similar issue, and it was caused by having a file in the print queue that would not print.
Open Print and Fax Preference, then open the Print Queue button. Highlight any files in the queue and delete them.
Hope this works for you
Nov 08, 2008 | Epson RX595 Photo All-In-One Printer
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
Says its ready till i try and print
Dell printer drivers try to 'phone home' with Ink usage stats .. even if you select 'no' when asked, they still try to access the Internet ..on install the driver modifies Microsoft Vista Firewall settings to permit this ...
So if you recently installed a non-Microsoft Firewall eg. ZomeAlarm your print driver will be denied access to the web and will refuse to print.
Note that 'deny' is different from 'time-out' ... to test turn off your wireless (or remove the ethernet cable) and ONLY THEN turn off your firewall - if it now starts printing you have your solution (go into Zone Alarm and Enable all Dell & MS print related software access to the Internet).
DO NOT browse the web with your Firewall turned off !!!!
Oct 14, 2007 | Dell Inkjet 720 Printer
HP2550N PRINT QUEUE WON'T PRINT UNLESS TURNED OFF THEN ON
This definitely sounds like a driver problem so you will need to delete the old driver and then install the most current driver and patches from HP Support.
Also Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Oct 03, 2007 | HP LaserJet 2550n Printer
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
