Question about Honeywell HV-180 18" Commercial Grade Floor / Box Fan
Need to purchase a new motor for this fan where do i go to purchase?
Air is cold. Compressor outside works. The condensor will run for a little while, then shut off while compressor is still running.
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. purchase a new capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor.bobicehouse_96.jpg
Sep 14, 2011 | Frigidaire FAS155K1 Air Conditioner
Our bathroom Nu Tone Model QT-100l fan is sounding loud and Rough. Can I purchase the motor part for this? If so will the motor be attached to the metal housing and I should be able to simply replace the...
The replacement motor is available from several sources online. The best way is to purchase the new motor assembly. All you need to do is remove the blower housing from the ceiling, there are three screws that hold the motor assembly in place. The whole job takes about five minutes. Here are a few sites with the motor.
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0 http://www.cshincorporated.com/product_info.php/manufacturers_id/33/products_id/11272
Aug 22, 2011 | Broan-NuTone QT100L Fan
My model 8663RP "B"-Unit Combination
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here: http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
May 02, 2011 | Broan-NuTone N-8663RP Combination Light...
I want a new motor for the patton 20'' cvt air fan
You can generally find new motors at an electric motor shop, check the yellow pages. However they are many times more money than a new fan. Then add time and your drive to get the motor, my recommendation is purchase a new fan, cheaper in the long run.
Feb 23, 2011 | Patton 20" CVT Performance Air Circulator,...
I have a Coleman A/C unit Model # BRCS0481BD and I need to replace the condenser fan motor. It doesn't look complicated but I was wandering can anyone post a how to tutorial. Thanks in advance, ...
Disconnect power to the unit. Remove the fan blade. Remove motor from mounting bracket. When replacing the motor, replace the run capacitor too.
Mar 10, 2010 | Heating & Cooling
Broan bath fan motor has bad bearings.New motor or new bearings?
The motor is usually not repairable. You can sometimes purchase the motor and fan separate but that is about it. Here is a link to a blog about replacing motors.
http://nutoneproducts.blogspot.com/2009/05/broan-bath-fan-motor-replacement.html
Oct 13, 2009 | Broan-NuTone Dryers
Problem with fan spinning on an outside unit. It is humming, not turning.
Only two possibilities. Check the fan motor for bearing play. If the shaft moves side to side or the motor is hard to spin then it is time for a new motor (note being able to wiggle the shaft in and out of the motor is normal, even new motors will do this). Other possibility is the run capacitor for the fan. Usually in a/c's they use a dual run capacitor for the fan and the compressor. this will usually be a grey or silver, round or oval cylinder with either two or three terminals on it. If there are three terminals, they will be marked, (C, HERM, and FAN) mark all wires to make sure that they make it back to the same terminal on the new capacitor. If there are only two terminals then it doesn't matter which wire goes to what terminal, but if there are multiple wires going to a terminal, those wires must be kept together on the same terminal. NOTE: the capacitor will need to be purchased from a HVAC service dealer or some place like W.W. Grainger or Johnstone Supply (these are wholsalers and you will need a business afilliation to purchase).
Jun 18, 2008 | Goodman CKL42AR42 Air Conditioner
Motor seized
I just want to know if I can purchase a NEW motor and what the cost is?
Feb 24, 2008 | Patton U2-1487 Floor / Box Fan
Honeywell HV-180 18" Commercial Grade Floor / Box Fan Logo
59 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
