Question about Sparkle Burnout Ruffle Pajama Tank Top
Where can I purchase this top and the matching bottoms
Tension
is a trial and error process
Aug 04, 2014 | Brother XR7700
The basket is cracked
On the bottom of the 'TOP PART WITH THE MOTOR AND BLADES" is a SAFETY SWITCH that must fit onto a small piece on the inside of the basket for the unit to run. If the basket is cracked and the small plastic piece does not match up the machine will not start.
Your options are:
1) Try to repair the basket to get the switch to line up
2) Go to the manufacture's web site to purchase a replacement basket.
3) Trash it all and buy a new unit.
Jul 11, 2014 | Fellowes DM8C Cross-Cut Shredder
I have started quilting a large quilt and having problems with the bottom thread showing through at the hole puncture. My backing is purple and the bottom thread matches the purple color. My top is made...
Use a universal #10 needle. The smaller the hole from the needle the less you will see of the bottom thread showing on the top. And I'm sure your using good quality #50 weight cottom thread, right?
May 12, 2011 | Juki Sewing Machines
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Purchased range used. Burner Head assembly with
Yes, you need a burner cap to sit on top of the burner assembly and create the normal star shape flame.
Feb 09, 2010 | Kitchen Ranges
Answer to no 18 question
Move match top right to bottom left of rubbish, then move the middle match along slightly to the left
the match that was top left becomes the handle .
Mar 12, 2009 | Nintendo Professor Layton & the Curious...
Kenmore 19233 computerized sewing machine
On my machine I find that my bottom and top free motion stitches are more uniform when I set my needle thread tension at 8 or 9. Also, you might want to use a top stitch needle.
Good luck,
SewReady
Nov 07, 2008 | Kenmore 19233 Computerized Sewing Machine
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Sparkle Burnout Ruffle Pajama Tank Top Logo
484 people viewed this question
Top Sparkle Clothing Experts
Da Doc
ray gallant
Erin Wood
Erin Wood
Are you a Sparkle Clothing Expert? Answer questions, earn points and help others
