Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Problem connecting to router
We have a Belkin 54G router. Two desktops are hardwired and work fine. We have three laptops. Two are wirelessly connected and working fine. The third (A Toshiba Satellite Pro) has been wirelessly connected in the past but after a IP outage today when all five computers were disconnected now cannot reconnect. This laptop stays stuck in "acquiring network address". We have disconnected, repaired, given it manual IP addresses, nothing seems to work. We also hardwired it which makes it work. When using the IP addresses provided by hardwiring it, the system shows that it is "connected" but in actual fact it isn't as our browser cannot pick up any internet pages. Any suggestions?
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    yes can you go into the router...hardwired you may need to go into admin and establish a new connection to the modem...
    Best Answer - Chosen by Voters
    Type in your default gateway in your browser window. Generally, I think that's 192.168.1.1 or 192.168.0.1. Then type in 'admin' for your user name and 'admin' for your password. Sometimes there is no password, believe it not. So you may find when you do this that you'll type in 'admin' for your user name and leave password blank... and then it'll work.
    Scholar:
  • 122 Answers
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
Posted on Jun 22, 2009
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
I have belkin g wireless that i have to constantly connect
I have experienced the same issue with belkin routers. First, test your laptop with other wireless connections {e.g. Starbucks, McDonalds, etc..} to see if your laptop's wireless adapter is working okay. If so then it sounds like your Belkin Router needs to be reset to the factory defaults and then your personal wireless network settings re-entered.
If that doesn't work it may have to be replaced.
Please provide feedback...
Mar 12, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
One of five PCs not connecting to Belkin 54G router
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Jun 22, 2009 | Toshiba Satellite Pro 6100 Notebook
Slow ping time
Ping depends on the server network and not the configuration of the laptop.If the ping varies, you need to check the network configuration.
Any further help, let me know.
Thanks for using "Fixya".
Jun 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Jun 01, 2009 | Dell Inspiron 6400 Notebook
Belkin 54G works OK with wireless connections but not wired!!!
In the end I replaced the ethernet cable with another one and it worked!!! That simple....................
Mar 30, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
May 24, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
199 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
