Question about Janome Memory Craft 9000 Computerized Sewing Machine
Cord i need a cord for won do u know where i could get one
Power won t stay on
1.check outlet to make sure it's ok
2.could be power cord
3.could be connection between power cord and sewing machine
4.could be short in wiring
if it continues, I suggest to have the machine checked
Jan 17, 2014 | Sewing Machines
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Brothers sewing machine
first check the outlet to see if it works
next check to make sure the power cord is plugged into the machine
correctly.
if you've done the above things, & you push the switch to turn the machine on & it still won't come on, then the machine needs to be
checked.
Sep 05, 2012 | Brother Sewing Machines
Bernina 1130 power cord won't retract
since the machine is a bernina, the machine probably needs to
be checked at a sewing machine shop, to see why the power
cord won't retract
Jun 03, 2012 | Bernina Sewing Machines
Nina ME 4123 won't switch on
is the power cord inserted correctly?
is the outlet working ?
if the answer to these questions is yes, then the machine needs to be check to find out what's wrong with it
May 26, 2012 | Bernina Sewing Machines
What is wrong with new home overlock serger when motor is slugish or won't move.
there is something wrong with the machine, the feed dogs are what move the fabric, it could be many different thing, the motor, some part is worn or loose or broken, power cord, it needs to be serviced
Feb 27, 2012 | Sewing Machines
Is there a fuse in a bernina 910 electronic sewing machine
Should be ,,if not in the cord ,,,check un neath ,,may be a panel,,
Dec 20, 2011 | Sewing Machines
I need the power cord for a Janome Sew Mini I just purchased from a friend who lost the cord and foot piece. Is it available anywhere?
Thesewingoutlet.com and bizrate.com both have them listed in stock, and you will probably find some on eBay as well. However, with purchase price plus shipping running around 40+ dollarsfor a machine that was only $55 new, you might be better off finding a new machine altogether that won't have any underlying issues that a used machine might.
Jun 22, 2011 | Janome Mini Compact
Janome Memory Craft 9000 Computerized Sewing Machine Logo
35 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
