Question about Craftsman 4 Cycle Blower/Vac
I need fuel lines for craftsman 358.797290 leaf blower
    Problem Solver:
  • 5 Answers
Whenever I cant find the exact stuff I need, try a local motorcycle shop. The fuel lines and such are very similar, often times you will end up with a higher quality fuel line for a few pennies more. Hope it helps!
Posted on Jun 24, 2009
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
I have a Craftsman Leaf Blower (made by McCullough) and the fuel tank is leaking - need a new tank. Model #316-794990, Part #MC 9228-334506. Thank you!
Before you spring for a new tank, check that the leak is not coming from around the fuel lines. If the fuel lines are not soft and plyable then they can not seal with the tank and may be the cause of the leak. They are replaceable and if that is the case you can get fixed up for a few dollars in parts.
Sep 13, 2011 | Craftsman Blower Attachment
2006 25cc 2 cycle craftsman leaf blower
The smaller line that has the fuel filer on it in the tank goes to the stem on the lower part. The larger line that just terminates shortly inside tank goes to the stem on the top of the carb with the bulb.
Nov 30, 2009 | Craftsman Garden
I have an old Craftsman leaf blower and it won't
most likley a fuel problem, start by replacing the fuel lines, fuel filter and diaphragm and gasket set in the carb. Non use is the worst thing for any 2 chcle small engine. The modern gasoline that contains ethanol, spoils in about 3 weeks and damages these parts.
Oct 31, 2009 | Craftsman Garden
Craftsman leaf blower will start but has no blowing power
Clean the carburetor and replace the fuel lines - The lines on mine were totally rotted - The larger hose crumbled in my hand - The fuel filter had long since fallen off....
Sep 03, 2009 | Craftsman Garden
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Nov 09, 2008 | Craftsman 4 Cycle Blower/Vac
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
282 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
