Question about Frigidaire FDF70S Dehumidifier
Frigidaire FDF70Sl dehumidifier power is on no light in setting area and motor wont running
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: 2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Posted on Jun 29, 2008
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: I have a frigidaire LAD704DUL 70 pint dehumidifier. Last year it worked great. This year, it has not collected any water in the bucket. The motor runs, it is on CO setting but still no water. I have c
    If you have a dehumidifier that is not producing any water then you are wondering what you need to do to get this thing to work for you. In some cases you may be able to do something and in other situations there may be nothing that you can do.
    If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
    A few things that can cause this are:
    The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
    The compressor has failed...if you hear a buzz for a few seconds, every few minutes, then you have a bad compressor or at least bad start components on the compressor. Either way it again is a costly repair.
    If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
    If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
    If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
    If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
    Also if nothing is running check the float switch or the bucket switch. Many of these switches are very touchy and if you do not have the bucket in place just exactly right it will not trip the switch to allow the unit to run. These switches often are more fragile then they should be and break easily. The good thing is that when available they are easy to replace and relatively inexpensive.
    There are some parts available for a few brands, but with the prices for most of the parts that you can replace running anywhere from 40.00 - 80.00 dollars, replacement parts with labor to install them, makes a repair more then the few hundred dollar cost of many of these dehumidifiers.
    As you can see there are quite a few things that can cause your dehumidifier not to work. Systematically go through the list and eliminate things to get to the bottom of the issue causing your problem and then decide if it is worth spending the money to try to fix the old unit. Only you can make that decision.
    Posted on Aug 14, 2012
    I e got a frigidaire energy star dehumidifier. Only the green power light cuts on. How can I get this appliance running?
    Thank you for your inquiry, friend!
    I see that you have a Frigidaire dehumidifier and the green power light stays on except it is not working. Typically, you have to set the dehumidifier in order to operate. What does your display say? If you can provide me with any additional information I would be happy to assist you. -Matt
    May 06, 2015 | Frigidaire Dehumidifiers
    I have a Frigidaire Dehumidifier, Model FAD704. the Clean Filter lights keeps coming on and the unit stops running. The filter is not dirty. I take it out and put it back in and unit runs for awhile and...
    Hello Winl, thank you for your inquiry!
    I see that you are having issues with your clean filter light coming on in your Frigidaire dehumidifier. From what you are describing it sounds like a possible issue with a sensor within your dehumidifier. I would recommend consulting with your manufacturer to see if they can provide any additional assistance towards a resolution. Best of luck! -OOS
    Dec 12, 2014 | Frigidaire Dehumidifiers
    I have a LAD704DUL frigidaire dehumidifier that will not shut off after being shut off, and not until the plug is pulled. Is this worth getting fixed
    Dear Peter Nicolle,
    according to the user manual the dehumidifier will not stop running for the following 5 reasons:
    • Windows or doors near dehumidifier are open to outdoors.
    • Area to be dehumidified is too large.
    • Air movement through dehumidifier is blocked.
    • Dehumidifier has been installed or restarted recently.
    • Dehumidifier is in the CONTINUOUS mode.
    You can find more information on the user manual on page 9 under the category DEHUMIDIFIER RUNS TOO MUCH.
    http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
    Nov 30, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
    I have a FAD 704 DWD, does it not have a power on light? I called for a question regarding a different issue and the service tech said it was very bad to not have the on light "on".
    Thank you for your inquiry, Lisa Cooper!
    I understand that the power light on your Frigidaire dehumidifier is not showing you the power light is on. It sounds like you could have an issue with your control panel. If your dehumidifier is running it could be that the light has failed. If you have a current warranty I would reach out to your manufacturer to see if they have a resolution for such an issue. Hopefully this helps. -Matt
    Nov 17, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
    I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
    Hi lynn crisp, thanks for your post!
    From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
    Oct 20, 2014 | Frigidaire Dehumidifiers
    I have a FDL70S1 Frigidaire 70 pint dehumiifer that runs for 3 minutes then shuts off. I have tried to set the timer for it to run longer but it wont. Do you know what is wrong with it?
    Hello lynn crisp, thank you for your post!
    From what you have explained regarding your Frigidaire dehumidifier it sounds like the sensor or control panel has become faulty. I would recommend resetting your dehumidifier and you can do that by unplugging the power cord for ten minutes. Is your dehumidifier under warranty? If so, you may want to reach out to the manufacturer for a resolution to the problem. I hope this information is helpful. -Matt
    Good Afternoon Friend,
    I understand that there is no water coming out of your Frigidaire dehumidifier, model# FDF50S1. I also see that the filter is fine and the fan is running. If you have your dehumidifier set up to continuously drain through a garden hose, make sure there are no kinks or clogs in the garden hose. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
    Jun 20, 2014 | Frigidaire Dehumidifiers
    When turn off. makes a humming sound. compressor seems to be running.
    Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
    Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
    Apr 25, 2008 | Frigidaire FDL45P1 Dehumidifier
    Frigidaire FDF70S Dehumidifier Logo
    44 people viewed this question
    Top Frigidaire Dehumidifiers Experts
    Charles T Nevin
    Charles T Nevin
    Oloyede Monsuru
    richie46
    Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
