Question about Ricoh Aficio SP C811DN Laser Printer
Rich Aficio C811DN PS job won't reset
I sent a print job from QuarkXpress to a Ricoh c811dn printer. The printer displayed Printing... for about 15 minutes before I selected to Reset all Jobs. The printer displayed Resetting Job... for another 15 minutes before I selected to Reset all Jobs again. The job still would not reset so I pulled power and network for over an hour while I did other stuff. I came back, plugged in power (no network), and the printer displayed Printing... same print job. Reset all Jobs... no luck. I've been trying to get a tech onsite but it's been very difficult given our location. There doesn't seem to be anything in the hardware/software manuals.
Q: Is there a lower level way to clear the print job from RAM or maybe hard-drive? I know there is a service mode, but I do not have documentation on how to use it.
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
SOURCE: page counter on RICOH aficio SP C811DN
Enter the menu of the printer pressing once the relevant button and with the up or down buttons find the list test print. Then press once # or OK (whatever the machine has) and you see Configuration page. By pressing once again the # or OK it prints the Config.Page, which somewhere on the top of thw sheet shows the pages printed (first the black and then the colour. Good luck!
Posted on Sep 09, 2009
  • 127 Answers
SOURCE: After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
Posted on Dec 01, 2009
newport74
  • 58 Answers
SOURCE: My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Posted on Feb 26, 2010
How do i change my ricoh aficio sp c811dn to english language?
push Menu button, then push down arrow to panel 4/4. The last option is "Language". Click OK, then you will see a list of languages with English at top. Select English and click OK
Dec 18, 2014 | Ricoh Aficio SP C811DN Laser Printer
Colour out of alignment on aficio c811dn ricoh.when i print a demo page,the colours are out of alignment.
The transfer belt is not calibrated or the ID sensors are dirty. Read the user manual on how to calibrate it. No manual? Go to ricoh-usa.com
Sep 29, 2014 | Ricoh Aficio SP C811DN Laser Printer
How do I factory reset my Ricoh Aficio SP C811DN?
Go into SP mode. Saw it there once when I was just fooling around in SP modes at work. Enter SP mode with pressing the yellow clear all button, then 107 and holding down the red stop button. .
Jul 17, 2014 | Ricoh Aficio SP C811DN Laser Printer
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
Why my ricoh sp c811dn printer only print black when I am printing a color job?
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 28, 2013 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Apr 29, 2010 | Ricoh Aficio SP C811DN Laser Printer
Printer blinks eratically when "print" is sent. Doesn't print.
try to go to printer preferences>maintenance then you will see something like speed and progress then disable status monitor.
Sep 29, 2009 | Ricoh Aficio SP C811DN Laser Printer
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio SP C811DN Laser Printer Logo
124 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
