Question about HP Photosmart C7280 Printer
No printing, just blank papers shooting out
When I print from my ibook G4, the 'printing processing' box comes up and completes, so I believe the problem lies in the printer.  The printer seems like it will print, but it just shoots out one blank piece of paper after another, until I hit the cancel button of the printer.
    Scholar:
  • 122 Answers
First verify that the printer is working by printing a configuration page from the printer itself. If it prints fine, uninstall and reinstall the printer with the latest driver from HP.
If the printer will not print an internal config page, replace the ink cartridges.
Posted on Jun 22, 2009
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Epson stylus color 880
This is a very late response to your query, but you did have it in the C46 section. It sounds like you have blocked heads but there could be other reasons such as a faulty print head or main board. If you still require help with this problem, please post a new comment to this effect.
Nov 18, 2008 | Epson Stylus C46 InkJet Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Ibook g4 - screen will not appear
Try adjusting the monitor brightness (F2). If you have an extra monitor, try connecting the mini VGA to see if it outputs a signal extenally. The videocard is onboard the logicboard....so, that is one way to process of eliminate.
Also, if you start the machine after the apple chime, hold down the OPTION key. This will prompt you as to which bootable volume to boot from. What this does though, is gives the monitor a signal before the operating system loads.....this usually eliminates the issue being software, but very seldom is no display a software issue.....
Hope this helps.
Oct 22, 2007 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Printing only the top quarter of the page.
Believe it or not all you have to do (probably) is to clean out your temporary internet files. This quite often works.
Nov 01, 2006 | Canon BubbleJet i550 InkJet Printer
HP Photosmart C7280 Printer Logo
288 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
