Question about Linksys Wireless-G WRT54G Router
How to reset my wifi router cd-r king LP-8616?
    Habit-Forming:
    New Friend:
  • 21 Answers
For reseting your linksys router, you have to press and hold the reset button on your router for 15 to 20 seconds ,
for more information about linksys router you can visit on LINKSYS Tech Support , here you will get all information about linksys router.
Posted on Jun 22, 2014
Lost cd download
What exactly do you need the cd for? If you set it up and cant remember how to access it, lost password etc, I would suggest resetting it to factory defaults by holding the reset button in for 10-15 seconds. After the reset, access it using a wireless connection (it should be called ciscoxxxx where the "x"s are numbers) and it should prompt you to go through the auto setup process again. If it asks for a password, the default password for the wifi should be on the bottom of the router. Rather than the password or key, it may ask for an 8 digit pin number also found on the bottom of the router.
Dec 11, 2013 | Linksys WRT120N Router
I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is not...
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
Oct 11, 2012 | Netopia Cayman 3347W-Ent Wireless Router
I have a CDR King Router L8186. I want to put a password
Hi
i had the opportunity to use both Smart Bro and Globe broadband internet with my CD-R King LP-8186 router. I had decided to document the configuration steps for both. For the most part, the steps indicated herein apply to both Smart Bro and Globe except otherwise mentioned in some areas. I had included the screenshots that would really matter and excluded the configuration that I left to their default values or settings. 1operation-mode.jpg?w=477&h=370
2wireless-basic-settings.jpg?w=477&h=370
3wireless-advanced-settings.jpg?w=477&h=370
4wireless-security-setup.jpg?w=477&h=370
5lan-interface-setup-smart1.jpg?w=477&h=370
Here's the LAN Interface Setup that applies to Globe. Please note that DHCP has been disabled because the modem that came with my Globe broadband subscription has DHCP enabled thus the need to disable the DHCP server of the LP-8186 router. Also, the default gateway of 192.168.1.1 is the IP address of my Globe broadband modem which is a Prolink Hurricane 5200 modem.
5lan-interface-setup-globe.jpg?w=477&h=370
The last part to be configured is the WAN setup. This screenshot applies to both Smart and Globe.
6wan-interface-setup.jpg?w=477&h=370
Lastly, if you are using Smart Bro, the RJ45 connector from the Smart Bro canopy antenna must be connected to the WAN port of the CD-R King LP-8186 rounter.
If you are using Globe, the Prolink Hurricane 5200 modem must be connected to one of your LAN ports (not to the WAN port) of the CD-R King LP-8186 router. With Globe, the CD-R King LP-8186 acts only as an access point and all computers connecting through it are actually using bridge networking.
Sep 05, 2011 | Computers & Internet
Guys..need help...bumili ako ng CDR-KING ROUTER CW-8196..nadedetect ko ung wifi signal pero walang internet access. pero pag direkta sa LAN ung net ko.malakas naman net ko..windows 7 gamit ko...
DUDE..simple lang yan...if meron ka modem...off mo muna modem..
tapos..un-install mo yung "ETHERNET ADAPTER"
den...from Modem connect mo to CDR-king Router - PC, tapos " restart "
and MAGIC...OK na NET MO..pati WIFI...
May 26, 2011 | Computers & Internet
Need a password to hookup my Netbook Ebook Reader.want to hookup to WiFi
1. you have to setup the Netbook inside the router
2. the router CD will have the instruction set to add a wireless device to the wireless device list in the router configuration.
3. to reset a password for the router you will have to set the router to default and go through the setup wizard again to reset the password.
You router manufacture site will have the instruction site to assist you with this.
Apr 13, 2011 | Dynex DXWEGRTR Router
With which method i can check my wireless card
try to scan or search for possible Wifi connection. if you want an easy access try going to McDonald's or Burger King which offer free Wifi access.
Apr 09, 2011 | Computers & Internet
I have a CDR-King LP-8186 router. I tried downgrading its firmware from v1.5a to v1.4d because all the firewall feature isnt working anymore. i download the firmware from...
You have to manually assign a compatible IP address on your PC which you used to update the router in order to access it. For example, if the router default is 192.168.1.254, then you have to assign the PC 192.168.1.200 (IP address), 255.255.255.0 (subnet), 192.168.1.254 (gateway) on the PC. You should be able to get in the flash the 2nd and 3rd parts of the firmware. After completing the firmware flash, do a factory reset on the router and you should re-configure it again by hand. Good luck!
Jan 16, 2011 | Encore Computers & Internet
I need to reset my wifi network password but don't know how
The router's password can be changed by running the routers setup cd. If you do not have the cd:
1.Open your browser
2.In the address bar type in 192.168.1.1 this will bring you to your router configuration.
3.put in your username/password "If you forgot your username and password you can always reset your router, if that is the case your router will go to back to default settings,In order to reset the router look in the back of the router and you will see a reset button, press and hold the reset button for 30 seconds, the reset button is located next to the Internet port on the router.
4. When your linksys router configuration is up, go to Administration.
5. change password that's it!! hope this helped. Good Luck
Sep 29, 2010 | Linksys Wireless-N WRT150N Router
I pushed the reset button on my modem to kick my roomates off it when it rebooted it didnt require a password in the proccess of resecuring my wifi it will not let me connect to the internet unless i plug...
you need to reinstall your wireless router...because it was reset to default...
as i know you need to go to the admin of dlink so that you can change the settings of your wireless router..
if you have the cd installer it is much better..follow the instructions and it will be fixed up...
Feb 25, 2010 | D-Link DIR-625 (790069292637) Wireless...
Linksys Wireless-G WRT54G Router Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
