Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint aquarius wf210 g washes but stops at rinse
This is the actual model and type
hotpoint aquarius wf210g model washes but does not rinse ¿ ??
hi need help i gues , :) machine washes fine then lets lets out water . all ok there.. now it should rinse and take the conditioner down and fill with water , but nothing happens here , no water comes in it just freezes so i have to restart machine and put it on final spin & pumpout which just spins it , prob is it never gets rinsed
so i checked the inlets the hot comes in thats a single valve /solenoid the cold is a double valve solenoid , i guess that cold valve is not letting water in for some reason , so i cleaned it with vinegar , and the valve is free it moves if i use a toothpick to nudge it up and down , also tried a valve from my friends old machine same model , but still made no differance , possibly his valve is faulty too , ......oh and incidently a few times when i advanced the machine to final pump out it did nothing , but worked after a few attempts any ideas i'm confused ¿ is it poss its not pumping out fully therefore , not letting water in to rinse..?
    Champion:
  • 249 Answers
That is a possabilty, make sure you have water going to cold valves put test bulb on the wires going to valves it should light] close Ire. that means you have current going to valves] get back to me if you can\t sort it
Posted on Nov 28, 2007
Water coming out of dispenser draw when starting rinse cycle
Make sure that the conditioner drawer is free of old soap residue because it cannot syphon out on the rinse cycle causing it to overflow.Hope this helps.
Good Luck.
May 09, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Require a manual for Hotpoint Aquarius WF210 washing machine
You cannot download a repair manual on line, you have to purchase them from Hotpoint,
However, if it is a user manual you require, then go to:
WWW.HOTPOINT.CO.UK
Click on after sales, and then on download instruction books, put your model in the box, and then you can download to your computer. or to your printer.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Leaking washing machine
Hotpoint Aquarius WF210 Front Load Washer Leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 01, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Programme not moving on
This is not something like a belt or a motor then...It's probably the Logic in the control system.
Your best bet is have a hotpoint engineer diagnose it - and fit a new control module. To buy from hotpoint they range from 70 to 90 Sterling.
In england the call out is £90 and they actually don't charge for parts if the machine less than 5 years old.
Feb 25, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
119 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
